DIY Reflector
I got the reflector today and have been busy! Nicely done, and the adapter sleeve is a great idea. As expected, my measurements translated into Buckese gives a not-quite-perfect fit, but that's ok, nothing a little work with a file didn't correct.
As can be seen above, I had to file an angle on the outer portion at the bottom to clear my connecting wires. The hole for the LED was a bit small, the reflector wanted to sit on the corners of the die substrate and actually shorted at one point, so I'm going to have to replace my driver spring, it's a bit worse for that little experience and is now a bit lopsided but now I'm using an insulator pad and all is well. I used Mother's Billet Polish to give it the shine, by hand, as I had no way to mount it to turn it. Literally an old T-Shirt and my finger pressed hard into it and turned by hand. I took a few turns at polishing top to bottom as well (an in-and-out maneuver, instead of round and round), in an effort to smooth some light ripples. The most difficult part is right at the opening for the LED, but I don't think it's affecting the beam much. There are a few rings, and it isn't quite as tight a beam profile as the OEM reflector, but there's a side effect that is rather pleasant...the color of the light is cooler from the Bucket reflector, while the OEM by comparison almost makes it look like the LED is de-domed. I assure you, it's not. I shot the following mouse-over's with the Bucket reflector first, went in the house and put the OEM back in, came back and took duplicate shots. The settings are all the same, I didn't even move the tripods. Canon G1X @ ISO1600, f/5.8 1/2 second exposure. (wide angle shots are f/5.6, cause that's how the camera rolls)
In all mouseover's Bucks reflector is first, mouseover for the OEM Raysoon F13 reflector.
First, the red oil drum shot. Wide first at 28mm followed by a second mouseover at 112mm. The drum is 97yds away.
For the next 2 wide/tele mouseover's, the garage door on the trailer shed is 58 yds away. Again, Bucks first, then OEM at mouseover.
I made a mistake earlier quoting lumens on this light, transposed a different light's lumens output from memory. This Raysoon F13 has a Qlite with 8 chips stacked on the inside, for a total of 16 chips and is making 5A at the tailcap from an Powerizer LiNiMnCo 26650 cell. Earlier tests when I first built the light showed 1124 OTF lumens at start-up and 1080 OTF at 30 seconds. I did not do full 30 second tests as I was doing quite a few and didn't take the time to charge the cell between em all for dead even results.
That being said, when I first took the reflector out of the box it needed some polish work. I tested it anyway and got 721 OTF lumens within 5 seconds. After a brief polish session, I got 1061.5 OTF with the stock set-up showing 1090.2 in between the two Bucket tests. After getting some file work and taking .040" off the overall length from the bottom, I have the reflector sitting solidly down onto the pill and making 1056 OTF lumens on the weakening cell. For the beamshots, I charged the cell back up.
So, while it may look brighter with the OEM reflector in place, it's actually misleading. There is more spill coming from Bucks reflector so a very similar lumens output is being dispersed more evenly. The color difference is quite apparent, and I like it! So yeah, I'll be keeping this reflector in the Raysoon f13! :)
Thank You Buck, for all the hard work and dogged determination.
