In effect that’s what is happening. The S3 works a little different than the S2, S2+, etc. Since the S3 doesn’t have a removable head, one needs to use a long screwdriver or some long needle nose pliers to reach the pill for tightening. Since the S3 has a removable chrome bezel that allows access from the lens side of things, I found it simpler to get the pill where I want it, then tighten the chrome bezel to exert the necessary pressure. I am able to hold the pill in place with a long screwdriver inside the tube. I use a jar grip to make it easy to tighten the bezel down. It was much easier for me this way than when I tried to tighten it down fully with the long screwdriver.
I do that with my C8 flashlights as well, when I use a dedomed led. The dedomed led focusses better with the plastic ring around the emitter removed, which makes the head assembly just a bit shorter. By not entirely screwing in the pill, and tighten the bezel/reflector on top of it, everything is nice and tight.
