Do your old (Efest) small IMR batteries hold their charge? (Mostly they do, several tests were done).
That sounds like an internal short. Recycling it is the correct response, as an internally-shorted battery can be dangerous. The most common cause of this is over-discharge.
I finished the last capacity measurements and updated post #57 with the results.
Keeppower 16340 (P1634C, 2015, black)
Voltage: 4.187 V - 4.136 V
25 mAh lost
Olight 16340 (ORB-163C06, cyan)
Voltage: 4.180 V - 4.096 V
27 mAh lost
Efest IMR 18350 (10.5 A, purple)
Voltage: 4.185 V - 4.150 V
14 mAh lost
Enercig 18350 (TN18350HP-700, grey)
Voltage: 4.191 V - 4.128 V
34 mAh
I know it’s a little past 2 months I have some life things going on that kept me from BLF. But I will check the voltage and discharge the 3 batteries I put in storage for this test tonight. Have batteries on the charger now. When they finish up in a couple hours or so I’ll discharge these batteries.
That’s cool, I’ll add them to the table in post 27 later.
Thanks CRX for completing that handy list.
No problem mate.
Got them discharged now. Fell asleep last night.
20r 4.09 discharge 2041
25r 4.16 discharge 2603
LG Hg2 4.18 discharge 2911
These batteries all fairly new. The 20r was basically brand new the 25 r had maybe 20 cycles.
Hg2 under 50 I believe.
The Samsung’s dropped about. .4 volt at almost 3 months which is good in my opinion. The hg2 didn’t drop much which surprised me some.
I have the data for the batteries I tested just keep forgetting to post them when I’m able to…
Ok. Finally posting. 2month test. All batteries are new. When I receive them I charge them discharge and then charge to 3.8v for storage. All tests done on skyrc 3000
I have been suspicious of my 30q batteries for a while. I believe I’ve been getting bad/fake batteries off and on over the past two years
Edits. :slight_smile: 4.20 and 4.15
VapePower IMR26650
4200mah measured 4081mah
4.20v start, 4.15v end
29 mΩ
Likita 26350
2000mah measured 2166
4.19 start, 4.15 end
90 mΩ
30Q light wrapper
3000mah measured 2795
4.07v heat limit reached 45C, end voltage 0v unrevivable.
30 mΩ
30Q dark wrapper early 2016 no date code under label
3000mah measured 2301
4.18v start, 4.07 end
42 mΩ
Efest IMR10440
350mah measured 244
4.16v start, 4.14v end
NI18350A IMR 7A High Drain
700mah measured 693mah
4.18v start, 4.15v end
73 mΩ
RBZone 14500
880mah measured 662mah
4.17v start, 4.13v end
294 mΩ
Windyfire 14500
600mah measured 587
4.18 start, 4.11 end
128 mΩ
VapePower IMR26650 self charging? :smiley:
When the moon is in the seventh house, and Jupiter aligns with Mars.
Or he might have just missed an Io :-)
