E-switch UI Development / FSM
Ok, you remember my changes better than I do! :FACEPALM:
Oh crap! I pulled earlier this morn, been sync'ing my local up and came across this FSM thing I keep forgetting about... :FACEPALM: again.
Will pull again. Actually sounds like TK has more in the works based on feedback she's been getting here: https://budgetlightforum.com/t/-/67518/33
Actually the only local changes I have to worry about was that FSM one and cfg and hwdef files. I got a lot of custom defs, then a couple settings I always use, etc. Between her and you, all my local mods starting with Anduril V1 are in the new Anduril 2 baseline.
Right now I got one set of Anduril 2 sources all in the same folder, and 2 solution/projects: for the 85 and 1634. My 1616 build is separate, so I need to bring it in to the common Anduril 2 folder, then I can build anything right in Microchip Studio for Win all from one common source code base! With (Microchip Studio (MS), only way I could set up different MCU's successfully was to create the project from scratch. It's really not that bad though, goes quick, specially since all the source code is in one folder. You do, however, have to mark all the .c files that are include'd with a "Build Acttion" of "None" so it doesn't try compiling them. It's a little pain but I understand why TK did it.
The way it's done (TK and you) with switches to support 3 different sub-families of AVR's is pretty cool.
