I'm checking on the current NarsilM V1.3 right now, and it's very hard for me to notice the blink at the bottom of the ramp. I can do it 20 times and can't be sure it blinks or not. If I do the blink, it's maybe at a low output level and quick. I don't think Mateminco has anything to do with it? I thought they used the version of NarsilM v1.3 provided by TA directly, so basically it's what I did in NarsilM?
Talking of FSM based Firmware in this case Anduril for new light
Ohhh - getting my wires crossed
Still having problems getting the thermal regulation stable without the hard turbo dropdown
sometimes it works and sometimes it freaks out heating up to unsafe levels
the stange thing is when I shortened the ramping table to 144 values the thermal regulation worked fine, but other things like 2x Turbo did not work properly
I would like to know if and how this values interact with the thermal regulation
//#undef USE_SET_LEVEL_GRADUALLY
#define HALFSPEED_LEVEL 14
#define QUARTERSPEED_LEVEL 5
basically the MF01S is ready to get produced but still the firmware does not work out
TA tested the thermal regulation to fail heated up to 100°C
Matemineco tested it stopped at 90°C
and I tested it
the thermal regulation freaks out and the light heats up till we stopped at like 100°C the MCU read 95°C when getting into temp check after such a freak out so there is no hardware problem
alternatively how can I prolong the time period when the hard turbo dropdown kicks in and how it its level defined it drops to like 1 minute or 90 seconds?
Honestly, I’ve experienced strange behaviour with temp regulation on my D4Ses. At first I thought it was due to calibration but am pretty sure that’s not the case. I haven’t been able to replicate the behaviour 100% of the time so haven’t mentioned anything since. Hard turbo dropdown on the D4 works fine though, probably a bit too aggressive for me but I may just undefine it and reflash at some point.
So I did a sort of proove as TK dont want to listen to Matemineco or Texas Ace
I could prove here that the temperature regulation starts to inchrease the current again above the thermal ceiling,
so it can oscillate the temperature up like seen on different tests on MF01 and MF01S
Video is calibrated driver with room temp and ceiling to 60°C
at one point it stays at between 80°C and 70°C and the current is at about 70% of Turbo
here is definately a command like stay at MIN_THERM_STEPDOWN 100 when temp >ceiling+5°C, missing that sets the max current when the ceiling is already overshot
it is a kind of problem above ceiling that will always happen if the light does not come to a thermal balanced system, it heats up like 5°C and then cools down only 2°C when the MCU regiusters oh wait ite getting hotter now
Man, Coming in here is like barging into a room full of geeks that ran out of coffee!
Some people need to take a chill pill and get over themselves… Lexel, talking to you man. Asking for help and being rude about it, seriously?
Toykeeper is trelling for last months first Texas Ace
then me
last Astrolux
that her firmware has no bug its perfectly regulating temperature
does not want to write new code Astrolux paying her because she claims there is no bug
It works only if you compile the hard turbo dropdown which does after 30s a hard stepdown then limit max. current to a fraction of turbo
We had here lights that you could fry egg on and still getting hotter
There is some sort of heat up oscillation if the thermal mass and heat ratio is making slow cool downs and fast heat up
Asking just for simple code to be written:
if actual temperature is >5K than ceiling stay at MIN_THERM_STEPDOWN xxx
ignoring the problem for last months now the MF01S could be build but still no working firmware that keeps the light at safe temperature levels
TA, Astrolux and me spent hours and hours trying to fix the hardware but its not possible as the code does not work above the ceiling temperature
I'm not sure how I would feel about being asked to develop open-source software specifically for a certain company/product without compensation. The beauty of open-source is that Astrolux or whomever else are free to use the software if they meet certain requirements. I'm not sure which open-source license TK uses, but most allow modification if certain requirements are met (usually, publish the modified source code, among other things).
Astrolux offered payment to get the thermal code changed and use of firmware as far as I know
they want to get this light to production asap
a few hundred dollars spent on Toykeeper make some code actually pays of in no time
they are sitting just for the LEDs on about 20,000$ already invested in stockpiling the good tint bins
just for the CRI95 SST-20 they got 11000 LEDs below BBL
Prototypes are made but lacking the final firmware to test and going to mass producing after reviewing those and make last adjustments
Dunno, I'm sure TK will respond to all this, but I could probably help, just may take some time for me to do - I can't cut my hours at work right now, and I'm bout sure Astrolux would not pay my rate. Even for $500, I'd probably lose my shirt on the deal from my current rates and lost hours on my regular full time contract.
It's very easy to under-estimate software/firmware - boy, if anyone should know it's me.
I don’t presume to speak for ToyKeeper either, but I will mention that when I was working as a software engineer, $500 would have bought you about two days of my time.
For a bughunt on unfamiliar hardware, where either the hardware or the software could be at fault - or even both together - that’s barely enough time to set up a suitable test & development environment, never mind actually tracking the bug down and fixing it.
Bespoke software engineering is expensive.
It scares me to even think about what ToyKeeper’s freely given work for BLF would have cost on a commercial basis. I’m deeply grateful that she did it, though, because my EDCs have been running her firmware ever since the BLF A6.
The tests have been done and traced down to a simple think the Temp management does
It starts to increase the output even when a lot over the Temperature set point
Solution is to make it stay at minimum MIN_THERM_STEPDOWN value if its noticeable higher than the set point
Sure Toykeeper can do this a lot faster than anyone else that is not familiar how the current temp code works
I have searched the Temp code with the setup strings and its clustered into different sections depending which setup lines are activated,
but I do not understand the programming stuff like
OR
I know this code is responsible for temp management, but got no clue how it works or how it needs to be changed or code added to prevent the heat up above safe value
so we know its running then on a constant current that does not heat the light any further not trying to regulate heating the light up even more
Its confirmed that the temperature readout of the MCU shows those high temperatures
Getting this fixed will also be an improvement to Lights like D4S which have no hard turbo dropdown
You are cheap! $500 is not a full day for me, and it covers about a week of my health insurance (2 adults).
500$ a day?
I have to work 7-8 days for that
guess it does not pay not to be able to do complex programming stuff
at least 12% of total income for my health insurance is cheaper then (children included)
Wow. Senior programmer here earns $100 per day. Minus taxes.
Contract work is a two way negotiation. You can charge whatever you want as long as the client is willing to pay you that much. The specified rate tends to be variable based on a number of factors such as whether or not you are presently starving, or don’t need the work at all, or even how deep the clients pockets are or how much they stand to make from your work, etc. If they don’t like your price, they can go elsewhere. No one is a victim.
It depends on the point of view. Whats the price, a company would pay to your boss for your work. And Whats do you get at the end of the month from your boss.
Probably an EU / US thing. I’m in a good company pension scheme, with healthcare and some more pension provided by the state from my taxes. The $500 is what ended up in my pocket. My employer would have charged you at least three times as much if you’d gone to them and asked for my services.
I had some discussion with Matemineco today
they seem to miss the blink at ramp floor
By default, there is no blink at the ramp floor.
I took out the floor blink a long time ago because it is pretty obvious when the brightness stops going down, so no blink is needed. It can still be added as a compile option though.
So… it has problems when compiled without the option to prevent those problems?
Yes, it can adjust the wrong direction when temperature is changing very quickly. This is a known issue which I want to fix when I have time, but until then, the hard drop option is an effective workaround.
I have already tried a couple times to fix it quickly, but it seems I will have to do it the long way instead. The plan is to build a PDE-based thermodynamics simulator attached to a code simulator so I can run tests without hardware, and then adjust everything until it works as desired. It will probably take a solid uninterrupted week of development to finish, and I have been too busy to set aside that much time.
Until then, the workaround keeps things pretty safe. It just tends to be a little more careful than necessary.
I’ve been listening, and trying to help when I have time. I’ve been a little busy though.
the temperature regulation starts to inchrease the current again above the thermal ceiling, … Video
Are you familiar with how PID regulation works?
It sounds like you might be a little confused about the “D” part, the derivative. It measures the slope of the temperature curve over time, and factors that into the equation. So the behavior depends on whether the temperature is rising or falling, not just what the absolute value is.
If it’s configured for 60 C and the sensor is at 70 C, it won’t necessarily reduce the power. If it’s at 70 C and rising, it reduces power. But if it’s at 70 C and falling, it assumes everything is okay and maintains a steady course. It may even increase power if it thinks the temperature is falling too fast.
In a similar manner, let’s say it’s at 40 C. If it’s 40 C and falling, it should increase the power… assuming it’s not already at the desired level. But if it’s at 40 C and rising, it may decrease the power even though it’s not at the limit yet. The response depends on where it’s at now, and where it expects to be in the near future.
Video
In this test, the driver is floating free and the heat comes from a heat gun. This isn’t really a supported configuration. Increasing by 40 C in two seconds should not happen in a real light, and will probably cause an overflow issue to happen because it’s changing so fast.
However, it appears to be responding fairly well despite the weird conditions. What you describe in the video as “definitely a temperature bug” looks like it may be correct behavior. PID attempts to steer into the turns, instead of waiting until it passes the threshold before it starts changing course.
That’s actually part of why this process has been so long.
Well, that, and I’ve been busy. And Mateminco didn’t ask to hire me and send me hardware until yesterday. I haven’t exactly been ignoring them.
- Apr 10, Mateminco asked if I could fix a problem in their light.
- Apr 12, I saw the message and responded. Astrolux and Mateminco haven’t been very good about respecting the code license in the past though, so I wanted to make sure that was cleared up first. It’s kind of a prerequisite for taking clients. So I sent info about how free software works and what Mateminco needs to do to be eligible to use it.
- Apr 14, Mateminco replied to say they understand and will keep working on fixing their product.
- Apr 25 (yesterday), Mateminco asked to hire me to fix it.
I’ve been pretty busy with FW3A stuff though… and also busy with other high-priority projects. So I need to take care of those things first.
