Thanks. Manual configuration every time I change EEPROM format is way better than every time. Though if there was an easy way to change the defaults - that would be great.
Ah. If you just want to change the default runtime configuration, like the stuff a user can modify by pressing the button, that can be done in the cfg-*.h file.
It gives me 2 menu option, then first I have tried everything from 1 click to 30 clicks. Then I just click the 2nd option 50-100 times to try to set the temp high enough it will never kick in. Yet it still kicks in almost instantly when the light is still cool to the touch.
Otherwise, get it hot, calibrate the sensor to tell it itâs only 1 degree, and set the ceiling as high as it can go⌠70 C or 40 clicks. That should give it a lot of headroom.
Not guaranteed to completely disable regulation, but it should at least reduce the chance of ever stepping down.
Lexel, I donât see any Java in your screenshot. Just HTML because youâve saved the page instead of the file. Also please note that Anduril is not a single source file. It consists of multiple files in several directories. Use bazaar to clone the code and you wonât have such issues.
Now the firmware seems to blink out 28.9°C as 2 8 9 I donât like, the MCU is very imprecise even when the room temp is set
itâs a wast of time to try to blink out another digit
It looks like you saved a web page as a .c file and then tried to compile it. Please use bzr instead, if at all possible. Youâve had quite a few issues due to downloading source files individually instead of using the revision control tools itâs meant to be used with, and using the right tools would avoid a lot of headaches.
It doesnât try to track or display fractional temperatures. The function which blinks out numbers has an 8-bit unsigned integer for its parameter, so the highest value it can display is 255. If you saw 289 I suspect the problem is user error of some sort.
Again, itâs not doing a decimal point. Itâs an 8-bit unsigned integer. The values go from 0 to 255.
The temperature itself is a 16-bit signed integer, which can go from â32768 to +32767, but the display function can only do 0 to 255. That means only the lowest 8 bits are displayed. If it says 238, either it thinks it is running at 238 C, or more likely, â18 C. Or some other number between â32768 and +32767 which happens to have the same bottom 8 bits.
Or it could be a mismatched version of the code again, including some of the recent changes but not others, which could easily lead to all sorts of strange behavior.
Does anyone have a ready to roll atmel studio project using the newest code theyâd be willing to share as a .zip?
Iâve just been downloading precompiled hexes recently but now I need to make some code changes so I took a look and thereâs TONS of changes everywhere from the older early summer version my atmel studio project was last based off of.
The build has been getting more complicated over time, harder to make it work inside Atmel Studio. It simply isnât designed for the sort of things being done in this code, like having a bunch of build targets which are detected at compile time by the file names.
Depending on your setup, it might be easier to use WSL (Windows Subsystem for Linux) instead of Atmel Studio, so you can use the same development tools it was made with. It basically makes a virtual container running a Linux distro. Either the Ubuntu or Debian flavors should work. From there, the instructions in the README file should be useful.
