Which of the available (two-wire) 0V-9.99V displays has the lowest power requirements for the display ? … The lower the better as it will be interfering slightly with the charging current … Which of the (two-wire) displays have an accuracy adjustment ? … Some of the three-wire displays have an adjustment potentiometer , but they need a supply voltage (on the red and black leads) and the other green or white measurement lead (+) needs to be used with the supply -ve lead … This is not really practical as I don’t want to attatch a separate 6V isolated supply to the display.
I would consider mounting these on my cheapy charger board chargers , but with a push-button or switch to turn on the display … A LCD display would possibly be better than a LED display as it would use less current … Are any available ? … Any four digit displays (0V-9.999V) available ?
Hmm, sorry, its working now, and it seems its completely accurate.
I just measured 4,20V on cell charged on Sysmax Nitecore 4-bay charger.
YOu can buy cheap universal table charger from ebay or banggood and modify it with this little thingy to voltage checker for all sizes of Li-ion cells.
