Emisar 21700!!!
You are going to love the K1 with the SBT90.2. If there was only a single light that I’d take with me, yeah right, it’d be that one. The K1 with the W1 is a amazing thrower, but it’s just not enough light. I actually like my green W1 a little better than the white W1 because it has more throw and it’s a greenish/yellowish beam- more yellow than in beamshots but still really cool to play with in fog. I put a W1 in an Emisar D1S, easy mod btw 5 min max, and I’d prefer this. The SBT90.2 K1 is one of those lights that even when you try it indoors you know it’s going to be awesome. Often throwers are kind of a letdown until you get to see what they can do with the needed space. But with 4500L and 420K cd it’s a top shelf light for sure.
Battery wise it’s up to you, I always have a lot of cells charged. I can’t tell the difference between using a 30T, 40T, or P42A. But the larger capacity does give a noticeable more amount of runtime. All that said I have a lot more 30Ts because I never use the lights long enough to test the capacity.
I got mine today. Neutral white XPL and warm sst20. I am very happy with the output and am playing with Anduril2. The only minor issue is the finish is not perfect. One small scratch and a ln imperfection in the anodising. It matches my FT02s in output.
I might have to get another.
Wow man that’s great thank you. Maybe I can PM you some time to get some advice on other lights to get? I’m addicted to Emisar (:
Hey All… question about the k9.3…
I cant seem to configure any menu past the first prompt. For example, I want to lower the stepdown temperature, so I do:
3c from off, gives battery voltage
2c gives current temperature
7h light flickers while I enter the current temperature
Thats it! I should get another flicker delay to enter the stepdown temperature… but the light starts flashing the current temperature again. Anyone have any clues for me?
Thanks!
In the last step (7H), keep holding until you see two short blinks. The first blink is thermal calibration, the following two blinks is thermal configuration. If you release the button after two blinks, it starts stuttering to enter the stepdown temperature (30°C + n clicks to set the threshold).
My plan is to make it more comprehensible in the UI chart I drafted a few days ago.
That’s a difference between version 1 and 2 of Anduril. You are highly recommended to read the Anduril 2 manual carefully. There is a section describing this:
Configuration Menus
Every config menu has the same interface. It has one or more options the user can configure, and it will go through them in order. For each menu item, the light follows the same pattern:
- Blink once, then go to a lower brightness. The user can keep holding the button to skip this menu item, or release the button to dive in and enter a new value.
- If the user released the button:
- Stutter or “buzz” quickly between two brightness levels for a few seconds. This indicates that the user can click one or more times to enter a number. It will keep buzzing until the user stops clicking, so there is no need to hurry.
After entering a number, or after skipping every menu item, it waits until the button is released then exits the menu. It should return to whatever mode the light was in before entering the config menu.
Thanks!
Thanks! I did read this but I think the first line thew me. “Every config menu has the same interface” sounds like no changes have been made since Anduril. Now that I read it again I see the difference.
This is amazing idea. Hank should make it!
Hello
I still can’t decide which emitter to choose for Noctigon K9.3
Can someone explain, what are the main differences between offered emitters.
CH1:
SST20, HP-L HI, E21A
Positive and negative points.
CH2:
Deep red, Green, Yellow
Why is each colour used, what are the advantages and disadvantages for each colour.
How did you decide?
I will buy only one flashlight, so decision in not very easy.
Thank you for your answers. :smiley:
Kind regards
SST20- great CRI in the warmer temperatures, fairly bright and throwy. Some people find it has an annoying green tint, especially at lower brightness.
XPL-HI- brightest LED option offered
E21- lots of available color temperatures, very high CRI with great red balance. Considerably less output than the other options.
Deep red- least effect on your night adjusted vision, won’t screw with melatonin production
Green- The human eye is most sensitive to green light
Yellow- I don’t know, some people seem to like it though.
Hey I just got my SBT90.2 K1 and it’s everything that you said. Absolutely amazing amount of light and throw. It rivals my 100 watt Firefoxes FF5 HID
I also got a KR1 with the W1 Green (Osram CSLNM1.F1) and i absolutely love it. I took it outside with a 10 amp 18350 and man that beam is wicked. I wonder if it would be possible for Hank to do a D18 with 18 of these bad boys
My last 2 that arrived are D4SV2’s - one deep red and the other SST20 4000K 95CRI. The deep red is awesome and I was pleasantly surprised with the softness of the 4000K.
All things are possible through Hank.
Jackson Lee had one built with W1 Whites, so it should be possible, and of course he’s sold deep red SST-20 builds, so he should be willing.
Great idea I’ll ask him if he can do that. I have a D18 with an even mix of 2700 and 4000’s that I love and I’ve been trying to think of another D18 build
I think I’ll also get a K1 with the Osram green
Almost. It turns out that the stress-shredder I had custom built only works on turbo. Deep red and SST-20 2700k in a swirl. Not compatible together on the current D18 driver, apparently.
He did tell me about the issue before shipping it, I said it’s fine (not really his fault, and it’ll still be a sweet one-in-the-world drag-racer)
Still a very sad day nonetheless.
Yeah I wanted a D18 with E21A 2000K but Hank said it’s not possible
Thank you for your kind answer.
Then I will probably go with Deep red for CH2.
Regarding CH2, I will order SST20 or E21A.
How long does this flashlight sustain full brightness before stepping down?
Because if SST20 will overheat in one minute, more lumens will not be much help.
Kind regards
Mine arrived today, exactly one month from ordering which isn’t too bad.
XP-L HI V2 5D 4000K on Channel 1
Deep red SST20 on Channel 2
Red LED on button which I turned off
Body in green, so I call it the Green Monster
I got the 5D emitters because the light is very pleasant and there’s plenty of it. I got XP-L HI V3 3A 5000K emitters in a D4V2 mule because it was the brightest setup available and I was going for max lumens but the 5000K is a bit on the cool side for my tastes. I have the 5D emitters in a D4V2 “standard” light and also in a K1 and D1. It’s my “go to” emitter I guess. Be prepared to pay a premium for those and also for the deep red SST20.
But I have seen the SST20 in a D18 and its pretty nice too. The high CRI has it’s advantages. One day I shall get a light with SST20 emitters just because.
I can’t really answer that. I would imagine they all step down sooner or later, but I haven’t seen any runtime graphs that say how fast each one does. I love having all of the emitter options available, but one of the few disadvantages of that is that it’s hard to tell how the configuration you want will perform.
Yeah, I’m not sure how much I’d use the 9.3. What I want is a “D4SV3”. 21700 (so more pocketable than the V2), lighted side switch (essential for finding a light in the dark), a decent non pressure clamp clip.
Nothing earth shattering just an evolution.
Great idea! I’ll take that with SBT90.2 :slight_smile:
