Emisar D3AA is available now
I have used both of these with my D4SV2, W2.
  • Shockli 26650 5500mAh 20A / 30A
  • Vapcell G53 26650 5300mAh 20A
Both work great, but the Shockli is probably the better choice.
Anyone have a good way to get ahold of Hank? Tried PM and email but no response.
See if the community can answer your question first? Hank is flat out flowing 219bs! :stuck_out_tongue:
What is the lumen and and candela of a D4v2 and D4Sv2 with the Nichia 219B, R9080, 3500K?
Iā€™d guess compared to sst-20 4000k it would be about 15% less lumens and 20% less candela. On a quad with clear optics you would still get a decent output though. Someone might have a more scientific answer!
I thought that too. I know the SST20 4000k makes 10,000 Lumen in the D18. So I asked Hank how much the 219Bā€™s will put out in a D18. His answer was10,000 Lumen. So 15% is probably a bit too high. The 219Bā€™s would need to only put out 8500 Lumen in the D18 for that to be the case.
Fireflies uses both SST20 and 219B in their lights, so we can see from their specs that the difference in the same hosts is minimal. The PL47g2 is essentially the D4v2, and Fireflies gets that to like 2500 Lumen in 219Bā€™s. The D4v2 in SST20 does 3000 Lumen. Maybe there is a difference in how hard each company runs their smaller lights but they are pretty similar Lumen-wise all things considered, especially the higher you run them. SST20 a bit brighter, but not by too much. The bigger difference would be in the beam profiles. The SST20 is thowier while the 219B is more floody. So even though they are similar Lumen, they will still feel pretty different from each other, especially in color.
8500 is more realistic.
I did this mod when the D18 first came out and got 7,714lm with slightly used 30Qā€™s and iā€™m pretty sure that was measured after about 2-3s. Dont expect 10,000lm
What do you think about 9A+noFET and SST20 (2700/4000K) in D4V2? If there is such an option. Is it better to use the classic 5A or 7.5A?
I dont know for sure but you might be able to just resistor swap a newer generation driver and make your 5A/7.5A driver and have a 9A+FET. For this size host 9A might as well be FET cause they are both too hot so in reality I dont see much purpose in going past the standard 5-7.5A. Only reason it exists is just to keep the LEDs from dying for a niche case.
I See a lot of people doing the 9a + FET on Reddit. It gives you a higher regulation which there really isn't a downside with sst20. Id go with it.
I think it is more common on multi emitter lights for sst20 4000k and below to get do in the 500-550lumen ranger per emitter. I don't know anything about the 219b's, but everything I've read they put out less lumens than even the 4000k or 2700k sst20. I would think 10,000 lumens is high for 219b or really even for sst20 high cri. I could be wrong.
[quote=contactcr]
[quote=@Lojik]
Thatā€™s mostly what Iā€™m prepping myself to expect. But in doing some math my expectations unwillingly swell slightly. I know someone asked Hank about the 219B setup and apparently he has some tweaks that people have reported push the 219Bā€™s well and is great.
So in just doing some numbers that other lights do is how I can see it happening.
Pl47g2 - 4 emitters - 2500 Lumen = 625 Lumen per LED.
EO7x Pro - 7 emitters - 3600 Lumen = 515 Lumen per LED
E12R - 12 Emitters - 6800 Lumen = 567 Lumen per LED
If I just estimate 500 Lumen per emitter on the D18, it still comes out to 9000 Lumen. And if I estimate it closer to what other lights are getting roughly, it exceeds 10,000 Lumen.
As I said, Iā€™m still tempering my expectations. But I am doing a bit of math and some wishful thinking. Now if there are reasons I donā€™t know about that would prohibit 18 219Bā€™s from hitting 10,000 Lumen, like limitations with the internals and drivers, then thatā€™s a different story. I donā€™t know about internals like that, but my math def has me hoping for the best.
In order to reach 555 lumens the 219b would have to be driven at ~2.3A. For 18 emitters thatā€™s >40A. Thatā€™s a lot, particularly for three 18650 cells and when you factor in other losses in the circuit.
Furthermore, some tests show the D18 with SST-20 maxing out at around 7500 lumens.
Just because a manufacturer advertises specific lumen amount doesnā€™t always mean the light can actually reach it. I think itā€™s unrealistic to expect 10000 lumens from a D18 with 219b but I could be wrong.
So! I have pretty good news, not great news but pretty damn good-
I Just received a dt8 with xpl-hi 5D, my first 5D in a couple months because of the whole yellow thing. Well, this 5D is not AS ROSY as the 6-8 months ago 5D, but it is WAY LESS yellow than the last couple months of 5D (from what I know, because like I said it's been 2-3 months). I'd say it's in between the yellow recent 5d and the more rosy one, but if I'm being honest it is CLOSER to the ROSY one.
I know there are at least a couple people who I've chatted with that will be interested in this info. Tomorrow morning I am going to make my best attempt at phoning this, but just know they are getting much better. They're not as good as they were, but right now they are a lot better than they have been.
Iā€™m certainly not asserting that I know. Hank told me what he expects it to put out, and here others are saying it may not be accurate. So Iā€™m just comparing it to the many 219B lights we have examples of. I have many of those 219B lights so I will certainly be able to gauge the output differences.
I know claims are not to be trusted, but does Hank usually overestimate his lights or was that just one persons setup that tested at 7500 Lumen. I would say 7500 Lumen on a D18 is kinda of underperforming, I would expect it to do quite better than that. The E12R is not far from that at all. But you mentioning it would take 40 amps does put things into a bit more perspective. Either way, I canā€™t wait to finally get something the size of the D18 with 219Bā€™s in it.
[quote=`Lojik]
[quote=contactcr]
There is something wrong with this math here. As far as I know, both lights use the same driver and have essentially the same parts other than the number of LEDs.
When the same number of batteries powers more LEDs, those LEDs will individually be dimmer.
Lumens figures are misleading. The 10K lumens is probably with the 5000K or 6500K emitters. According to SKV89ā€™s test, the E12R with 219Bs only put out 4300 lumens.
Yeah I saw that and donā€™t believe it for a second, Itā€™s my brightest 219B light so if he got that figure, there was an issue with his testing or his light, Vihn produces some weird ass test numbers sometimes too as do others. Luckily I have many lights to compare and Iā€™m not worried about one test when I can just do a comparable eye test and see if itā€™s lacking compared to other high-powered lights. Fireflies also specs lights out with 40Tā€™s so itā€™s not like theyā€™re milking every last Lumen.
The Nov-mu claims 5500 Lumen yet itā€™s been tested at 7000+ at power-on. I have progressively higher and higher 219B lights and the E12R is as expected atop them all. If thatā€™s how many Lumen the E12R makes, than every other manufacturer of my lights are straight liars.
Vihn just tested the Thor II at like roughly 400-500 meters less throw than what everyone else is getting, does that mean thatā€™s what all Thor IIā€™s actually throw? Obviously not. One thing we can count on, is everybody will be getting different numbers so itā€™s pretty irrelevant. I will look at and trust side-by-side comparisons as thatā€™s where a light will pass peopleā€™s tests or not.
Edit: One more thing, D18 in 5000k-6500k is rated closer to 14,000 Lumen like the Astrolx MF01S and the Mateminco versiĆ³n. (Except those are rated at 15,000 Lumen in the 5000k-6500k versions)
Letā€™s do some math to determine the most optimistic, best case scenario numbers.
Iā€™ve heard the D4V2 pulls 18 amps with 4000k sst-20s from a high drain cell (30Q or VTC6). I canā€™t find a source but weā€™ll just use this for my estimates.
This means the LEDs are getting 4.5A each, and have a forward voltage of about 3.5V
According to Lygteā€™s tests, a 30Q/VTC6 drops to about 3.7v somewhere at around 18A drain. This means a flashlightā€™s circuit including the springs, mosfet, and traces will optimistically drop about 0.2V at higher currents.
Since the D18 has one spring per cell but other parts of the circuit have resistance, Iā€™ll say very optimistically that the D18ā€™s voltage drop from the batteries to the LEDs at 60A is 0.3V. This is probably a very optimistic figure and the real value should be higher.
Right after start up at a 20A drain, a 30Q/VTC6 drops down to ~3.65v. (Right at start up, <0.1Ah drained).
3.65-0.3=3.3V
At 3.3V, the 4000K SST-20 consumes 3A and produces 720 lumens. 6 of them (6 per 18650 in the D18) consume 18 amps of power (should be close enough to the 20A assumption).
720X18= ~ 13 thousand LED lumens. This is before light is lost as it passes through the optics and the lens.
So conceivable, for about a second or two after start up the 4000K D18 might produce 10 000 lumens, but LEDs lose their output as their temperature increase so that output will plummet after just a few seconds.
This is a very optimistic figure, and done to the best of my knowledge. Now if someone has a clamp meter and would be willing to measure a D18 at turbo, weā€™ll have a more accurate figure.
This is the kinda breakdown I was hoping someone could give. I know even things like spring amp ratings have to be accounted for (Thanks Texas Aceā€™s WildTrail WT90 group buy thread). So I know there are real limitations and I was wondering how they broke down in a D18 with itā€™s internals and these emitters. So thank you for the ā€œbest of your abilityā€ break-down kind sir.
So going with higher amp/lower capacity 18650ā€™s could hold it technically a smidge longer? But at this level with this many emitters, it would likely take 4 cells to see any gains. Now I get why MF01S can do a bit more Lumen with the same amount of emitters as the D18.
