Each of those optics is 35mm so a total height of 100mm only for optics then because each has it’s own threaded bezel (way better than a bezel that needs screws, no comparison) that adds around 8mm more per each optic, results around 130mm by 43mm head, so just a bit smaller than RS80 (25mm smaller height), by no means a MINI. I would not consider RS80 small by any means with a total weight of almost 1kg of flashlight (900grams including cells), the RS80GT is even better with a weight of 1.25kg including cells.
Random showerthought, I know it’s a pipedream given Hank’s preference and orientation towards larger high power lights, but a 14500 scale D4 would be a treat.
Source some signature red mini-triple MCPCBs and use the same triple optic that Lumintop used in the FWAA or source the maker to do a narrower spot optic, and have the design be literally a shrunken down D4V2 with some design alterations to make up for the size differential, or maybe even use current on hand parts like switch boots/rings/pcbs to lower BOM for fab. A captive pocket clip would be a treat.
i had been hoping for the last few months Hank would make something along the lines of the YLP Unicorn / S2r Baton- single emitter, 18650 (or 14500!), TIR optic (or even SMO/OP reflector), CC driver, tail switch pocket light.
either that, or Please make a 21700 KR1. A 21700 KR1 would make that light even more so the best pocket thrower on the market!
or, I'm voting for JaredM's KR4S, with Ledil Angie optic.
Curious what the lead time is when placing an order? I placed an order the Jan 6th, so my digital order is lost and impossible to check on the website. Still haven’t received a notification with tracking, so I’m a starting to get a tiny bit worried. Not in a hurry at all, just want to make sure this is normal.
Nevermind! What a surprise! A few hours after posting this, my order arrived
Unpack new DM11, stick in a battery and wow, pictures don’t do justice to the beautiful effect the aux LEDs have in combination with the TIR lens. Very very nice!
