I can’t comment on the retaining ring clearances, but those look like warm white button LEDs and it’s been widely established that the brightness not being even is normal specifically for that color.
Can the back-lit button on the D1v2 be turned off? I don't need it on when the light is not in use and I most definitely don't want it on when the light is in use; annoying as hell. Does Hank offer the option to have a regular, non-back-lit button with the black boot?
I think it looks kind of cool. You lucked out that it happened to be the LED on the “bottom end” of the switch as the light tailstands. If it was on the sides… much more “askew” looking.
You got lucky that it's bottom one.
I got one on the side, that is dimmer. I Asked hank about it, and received this answer
"It's normal for this small LEDs to have different brightness, since they have different VF value."
from my understanding Its peculiar bad with the warm white.
That's why for next purchases I chosed cold white.
Testing them is probably to much labor intensive
And yes, it's worst in reality, then in the pictures...
Hi Hank. Random question. How do you prevent particles from getting on the reflectors/lens when you assemble? Is your lab pressurized? Any recommendations to help prevent contamination? Thanks.
I think this is the common issue for the B35AM LED itself, the MCPCB is the best that we can produce, and there is no soldering issue whatever.
The LED will not die at high current (3.6A), but the smoke will come out on turbo mode.
We plan to reduce the current of the B35AM LED, this is the only way to prevent the smoke, only that the output will be reduced as well unfortunately.
