Don’t know what happened there. I didn’t “resurrect” this thread. It was at the top of the “Recent Posts” list when I posted in it.
Someone either posted before me and then deleted their post, or some other shenanigans took place. :question:
Again, I love the D4. Great light. But it is not really best-suited for use as weapon-mounted-light. There really is no debating this. In a high-stress situation requiring IMMEDIATE action (when your fine-motor skills go to crap), you don’t want to be fiddling with an e-switch and/or trying to remember how many “clicks” it takes for something. Also, you want that light available NOW, not in 2.5 seconds, or with a “soft on” UI, etc. A good WML is also designed/constructed for hard use. While the D4 is well built, I doubt it’s been subjected to a rigorous T&E phase with impact/drop tests, etc.
I would rather use the right tool for the job, especially when it comes to something that you may have to depend on, IMO.
I don’t remember anyone mentioning remote pressure switches previously, but I am not really a fan of them either. However, a quality one that has been designed and tested for a specific light is going to be far more reliable and rugged than an a cheap e-switch. Also, the reason I mentioned a preference for a “shrouded” tail cap switch is to mitigate the possibility for accidental activation.
Even a non-shrouded tail-switch is leagues better in that regard than a fully exposed side switch.
Personally, I don’t think a shotgun is the best choice for HD either. Of course, it’s always best to use what you know and are proficient with, but at CQB distances the shot spread of a typical shotgun is still pretty small, requiring you to aim with relative accuracy to hit your target. They are also bulky, heavy, slow/awkward to load, and have a very low round capacity. Unless it’s an SBS, it’s not going to be the easiest to maneuver inside a structure either, nor easy to operate with one hand if needed. They are also LOUD. If you fire a shotgun indoors without ear pro, you WILL have immediate hearing loss/ringing, which can be very disorienting (and possibly result in permanent hearing damage). The best guys around at using/manipulating shotguns are seasoned 3-gun competitors. If you ask any of them what they would recommend for an HD gun, I doubt any of them would say “shotgun”.
A 4000 lumen light can certainly take out your OWN night-adapted vision temporarily as well. You accidently hit that switch close to a white wall, your night-adapted vision goes to crap for several seconds too, and if you keep the light on, you give away your position (hence the concept of “light discipline”). Also, a high-lumen flooder is great close in, but probably not the best tool for PID past 20 meters or so.
The preference for primary cells for use in a WML (specifically for HD) instead of secondary (rechargeable) cells is not so much a concern about the need for “prolonged power” but more about having full power when it’s needed, even if the batteries have sat for an extended period of time. Primaries have a much higher energy density, and a much longer shelf life.
There is a shooting range/club in Miami with a full-blown multi-story “tac village” with night ops that is open to the public? Where is this? What is the facility called?
Fair enough. It’s certainly better than nothing (if used properly), and I suppose there are plenty of worse options out there.
Respectfully, I have doubts on this. If by no other evidence than your choice of light mount.
If true, I’d be interested to know specifically which of the “best” dedicated WMLs you have tested/compared to the D4, and how/why you concluded that all of them were inferior in that role.
