Good observation Scott, by having the bench in place (with shelves and stuff at the end and boxes for tools attached) it will make it very difficult to lift several hundred pounds of lathe into position. Limit’s it to 2 people, and the boxes on the end of the bench will compromise that persons position. (similarly, any hooks or nails on the other end may well gouge someone)
Not trying to be critical, just making an observation based on years and years of carrying heavy items.
Don’t know yet. Haven’t figured it out. Progably will have to rent an engine puller and have a guy drop it off. Don’t want to use people. People can drop things and Murphy is usually on the heavy end.
Unfortunately, there is only one place the bench can be and it’s a bad place, because the area is narrow and it is higher than the “floor”, because the area for cars is slanted at an angle and the only areas that are flat, are on the edges. The only other way would be to have the bench out, load the lathe and then pick it all up and that would be over 500# and still no more than 2 people, because it still has to go against the wall. No good solution has come up yet.
I have a chain hoist bolted on my ceiling to lift stuff between 150-800lbs. It was cheap and has been useful on multiple occasions. If you have it mounted on a bar you can get some side to side shift out of it.
Was thinking of something like This to lift the pallet or lift the lathe from the pallet to bench height. I’ve used other types to lift garage door and deck beams weighing 60lbs a running foot into place. They make midget ones for lifting wall cabinets as well. I’ll be using both large and small hoists in the next month and swear by them. Rental companies let them by the 1/2day, 3 day, week. Have some 4’ 4x4’s on hand to set the pallet on at deliver so the jack wheels can slip under the pallet.
Possibly a bit, but it’s not actually mounted at that spot anymore, so a bit of a moot point. What may be hard to see is just how close to the end of the boards it’s mounted. In the spot in the picture it has lifted my lathe, manual mill, and 60 gallon compressor without issue.
Last weekend a friend of mine moved his Grizzly mill/lathe (600+lbs) using a engine hoist. They almost dropped it when one of the chain hooks came loose. No fun at all moving these beasties.
It's been a very long day, but I will be using a Cherry Picker, (engine hoist), to move the lathe. I have to rent it and a pallet jack. They also have to deliver it here and pick it up, so it will cost more to move the lathe, than to make the bench. Oh, well, life is what it is. I am a loner, in real life and do not know, or wish to know, anyone in town. Even if I did, I would not want to have people try to pick it up. One false move, someone gets hurt and I get a law suit, no thanks. Strange how I am so different in an anonymous forum...
Anyhow, The lathe comes in on Thursday AM and the cherry picker and pallet jack come in Thursday afternoon. I have purchased slings/straps to lift with and I will be doing it all by myself. I will have to pick the lathe up, in the back section of the floor, where it's level and then push the bench under it, lower it, align and bolt it down and then use the pallet jack to move bench and lathe back to the far wall, (where the regular work table is now) and slide the bench/Lathe back into the slot where it is destined to be. The floor, at the back of the garage, has no slant, that's why I have to move it all at that end, where the floor is all flat and then slide it along the wall, to where it will be. The wife says if I kill myself, she's going to beat my arse. Kind of like beating a dead horse.
Should be an interesting day and fun for y'all when I put up the video. Hell, that means I have to wear clothes that day!
That reminds me of another lathe safety tip… don’t lathe in the nude… or solder in the nude… We don’t want see your grubbins splattered against the wall. Hmmm… or do we?
Maybe I am being naïve, but wouldn’t the delivery people be able to help you get it on to the bench? It would save you a big task, and some money.
I also agree with the statement above, and I was going to post this before:
You should change your user name to just “Lumens”, because you sure don’t look old. Maybe all the hard work is keeping you young.
How did the truckers bring in the lathe put it on the truck and how do they plan to unload it from the truck? Can’t you borrow those equipment and muscle power when they deliver?
They may have a Tommy gate and pallet jack or possibly one of those tail gate fork lifts but not a cherry picker and it’s usually curbside only for liability reasons. It should be crated as well and need unpacking/unbolting from it’s pallet first anyway. It would be wonderful if it were the last delivery of the day with a curious and helpful driver but not very likely. At least not around here.
Liftgate, pallet jack, to set it on the curb. Yes, for liability reasons, they normally don’t do more. The driver will set it in the garage, I already conned them for that much, but that’s all. I am not concerned about doing it myself. In fact I prefer it that way. It will all be fine.
Looking young runs in the family. To me, I look 60 and that’s my age, so it looks like what it is. To me, it’s old enough. Average age expectancy in the family is 62-65. Grandma was the only one to ever make it farther, but she was a mean old bird, LOL.
Hopefully the engine hoist straddles the bench from one of the sides—it’s sure not going under those bottom 2x4s—you might have to borrow some ones weight on the lift—if you boom out further than the front wheels they tend to tip forward—ask me how I know— every hurricane scare I have to load my 15k generator with(you guessed it a motor hoist) in my p/u
