XP-G3 V1, Intelligent temperature control setting was high The possibility that XP-G3 V2 is getting better is high.
219C V1, Intelligent temperature control setting was optimal.
219C V2 is set down, and turbo step down is done immediately.
219C V1, the coloration of LED is also wonderful, it is the best thing if it works normally
Personally I liked the v1 tint a little more. Though there isnāt as much difference between v1 and v2 - camera canāt see it, eye can⦠a little. Color rrendering is nice on v2 as well, so it looks like is still 90 CRI.
v2 - Turbo is stepping down after ~80-90 seconds and pretty slowly. I like the 3000lm High mode - wit a little wind and not too high temperature it can run for ~90 minutes straight, without stepdown. With the computer fan I mentioned it was ~37-38 Celsius.
Also, while the body temperature was controlled nicely in v1, the driver temperature was another matter, my light was capable of runniong few minutes on turbo without stepdown, but after that it was shorted - I could not turn it off. So I suppose ābetter darker than sorryā
Would they fit if you remove the white plastic rings or are they just too long?
I suppose if you were going to use protected cells only you could swap to a shorter spring.
Mtn Elec sells a nice spring that compresses really well. Iāve used these when I needed to fit a long cell and the stock spring just did not compress enough.
This is a new spring that is quite short. It looks great for long, protected cells, but might not be long enough for short, unprotected cells. I have not tried this one.
You could buy 4 or 5 of each and try them out, assuming you can solder.
I have a nichia v2 and can confirm, that on high (2nd highest level-3000lm?) it will run for around 45 minutes until first recognizable step down.
Lamp was tail standing during test run in my bed at 23°C ambient temp.
Just touched it shortly now and then to feel the temperatureā¦
It was almost cool, and heating up very very slowly but constantly until step down.
On highest level step down happened after 2 or 3 minutes⦠Did not measure that timeā¦
