Finally got my MF01 working again, now this is what the MF01 should have been, running TA Driver NarsilM. Not sure how much lumens but definitely brighter than my Haikelite MT03.
Ceiling bounce MT01 750Lux, MF01 1075 Lux.
The original driver has some advantages, the TA-Driver didn’t have. It is a Boost-Driver. That means you can use the maximum output with almost all charging-levels of the battery.
With the TA linear-driver you will only be able to use the maximum output level if the Voltage of the batteries is over or equal the Vf of the LED at this output-level. That means you will have it only in the first 20 percent oft the battery-charging-level, e.g…
But with the TA driver you will get more light out of the flashlight.
The change is not verry easy, because you have to change some traces/connections on the led-board/mcpcb to make it compatible to the TA driver.
The drivers of the first flashlights was buck-driver, that means they didn’t reached Tubo mode for a long time, but they had a 6V layout of the mcpcb. Thats why the first flashlights were easyer to mod with TA-driver.
I’m seeing some reports that the Nichia version, compared to the XP-G3 counterpart, is noticeably less bright. So I’m now torn on buying the Nichia version to go with my XP-G3. I already have a NW Olight x7. I really don’t know if the Nichia version will be a better upgrade. Looks like the output will be the same.
OK, i didn’t know. But it has been said that V2 and V3 should hold maximum output level for a longer time.
I only have V1 and a Lexel-TA-Driver I want to change.
But the drop in the output-level of the V2 is less hard than with V1. And It is hard to say what they did improve at V3.
What’s confusing is, how do you tell V2 from v3? I just bought the recent XP-G3 version (December) right before it went out of stock. I’m thinking version 3?
I just said F-it. I just bought the Nichia 219c version to go with my XP-G3 version. Hopefully I won’t regret it even though it won’t be as bright as the XP-G3. I wonder how much hotter it gets over the XP-G3?
At $78.00 it’s just too good to pass up. Now, what the hell am I going to do with three flooders? LOL. (2 MF-01 and Olight x7 NW).
From 219C V 1 to 219C V 2, the yellowness becomes stronger,In addition, the green color appeared again this time :cry:
I am sorry it got worse.
There is one no screw.The spring position is misaligned.Making is also complicated :confounded:
There were two LED wiring.
