Love the shape of that blade . . not a fan of mixed grip materials, though.
I had this a while ago.
Purchased with a Ganzo704.
...and because i got the Ganzo also, this one just had to go. Ganzo was better IMO.
I felt the same way at first, I used to like symmetrical knives better. The asymmetrical looked "broken" in the past to me. But since I now hold the EL08 and the Navy K507 in my hands, my reservations strike me as silly in hindsight. Especially the Navy should not miss in any collection. The slimness and smooth clip surface make it such a great knife and it's on sale. At least if one doesn't mind that the design is stolen from a 400 dollar knife.
I like my EL08, but it has some issues, detent ball tension is a little strong making it hard to flick open and the cut-out of the frame lock has some sharp corners. I am a little hesitant to recommend this one. The EL01, 909 have better build quality when I look at the finish.... but the EL08 is certainly a beast when opened and the perfect knife to use with gloves, because the grip is just massive and ergonomic... and the lock engages with authority. Overall a knife for people that think that the EL01 is too flimsy. ;-) The handle screws are Torx T8! ... ha... that's the size of the pivot screws on other knives.
You had me on the Navy at sale, but argggh . . another mixed grip. I’m not paying $400, but I’d buy the clone if it looked as good. Is that 909 the same as that green handled Land - that is a nice looking knife!
I have both the G10 and micarta version of the EL02, and prefer the G10 from Lazy Lizard.
The G10 is more grippy, and I have noticed that the black color on the micarta handle has worn some, so that in places it looks more brown.
Absolutely wonderful knives. Have used them camping and at work, and they hold an edge well and have perfect lock up.
As was stated earlier, the stone washed finish on the G10 version also hides small scratches.
I actually LIKE the shape of the handle. I find it fits my hand well. I guess to each his own.
Has anyone with the EL02b found that the axis lock spring loosened up at all after some use?
I have noticed that mine has loosened up some, but not much.
I would be worried if it got too loose without a tremendous amount of use.
My G10 one was definitely stiffer than the micarta one, so I would say there is a fair amount of variation.
I thought I’d post a follow-up. I just ground the offending raised area of the handle using my random orbiter sander and now the handle is fine.
There is no need to take the knife apart to do this but initially I tried to do so. There was one screw on one side that wouldn’t come out. It would turn and the head wasn’t stripped but the threads must have been.
I’m not sure because it wouldn’t allow me to take one G10 handle off. While disassembled I checked out the axis lock springs. It looks like they are tack welded/soldered/glued on the spring end but I think they are really kept in place by a shallow compartment formed by the G10 handle when assembled.
I thought about simply removing one spring to see if it would lessen the tension (evenly) and make the axis lock easier to opperate. I decided not to potentially mess up this knife after all the grinding work I’d just done but that’s a possibility.
So, if anyone is really bugged by the bump in the handle…it’s easy to remove. I really like this knife so I’m glad the “fix” was relatively easy.
Got any pics of your handywork there Bryan?
I’m not all that handy but here’s a quick picture.
Hopefully you can see that there is no longer that ridge between the fingers.
Here is a stock picture from the internet. Mine has the triangle type pivot however (not shown in my pic).
Luckily my fingers “fall” between each part of this “triangle” but I will probably sand it a bit. Great idea Bryan.
It worked for my fingers as well when I held it a certain way but it was annoying when I wanted to hold it in a different manner. Now I can hold it any way I want to.
