Fake chargers (XTAR, Nitecore)!!!
Me thinks that you thought that I was talking to about your post in the first place, though I was simply trying to give verge's post some context.
You did follow up troll, though:
[quote=marcl] There have been problems with fake Chinese food before and to my knowledge the only way to tell is the fortune cookies [/quote]
Nope, I know no shame.
Anyway, off topic enough, fake or not, as long as my charger's not simply weighted with lead shot, and continues to charge batteries to a consistent level, I'm happy.
And especially suprised since I got it off FleaBay.
You know no intelligence neither! Read the whole post not one line, then you may understand what I said.
Dudes, get a room, all of you :D!
Im thinking about dissembling one of my i4 V2 just to take a look inside of it and post some pictures here, perhaps someone will be eager to compare them?
What do you say, should I?
Is there no way you can check the serial no with the company via email first. I’m not sure you will learn much taking it apart. What if they did that when they copied it? It should look the same if they reverse engineered it.
Marc.
It is just like marcl said. Two different chargers could look exactly the same both inside and outside, but still the other might be fake. Reverse engineering is very common in China. It is also possible that the fake products come from a same factory as original products.
I bought two nitecore battery chargers (i2 & i4) from this seller bellow from ebay.
http://stores.ebay.com/chingsumsum-super-store/Battery-Charger-/\_i.html?\_nkw=nitecore&submit=Search&\_fsub=5907200&\_sid=208716131
i2 for $16 and i4 for $22 (make offer) and with EU power cord.
Bellow is the answer from nitecore if they are original or not,
Hello Sir,
Thank you for your email. After checking the serial number, they are original from NITECORE. Thank you.
He send everything with tracking number and received faster than other stores! (10 days to Greece)
This puts a whole new question about the ramifications of fake chargers:
Here is a photo of recent Finnish accident with official iPhone charger:
13 year old kid got electric shock and got hospitalized..
So a real might not be any better. :(
Lesson of the day - charge your devices through USB ports and hope for the best?!
How did this happen?
Also, a Samsung S3 exploded whilst in a pocket:
There was me with my SGS2 hoping it was confined to iPhone….
That type of accidents is the reason I have added a 5000 volt test to my charger tests. Weak isolation and very short isolation distances will usual break down when the 5000 volt is applied.
And it is often a problem with the cheap usb chargers (Se table at bottom 5KV is 5000 volt).
Note: A passed 5000 volt test does not say the equipment is safe.
Google translated news story
Long story short: The boy was handling the phone when being charged, there was some flames coming from the charger and the boy got electric shock.
My spouse has obtained a bunch of those wall wort chargers from eBay sellers for various camera and phone batteries and she charges her Samasung phone battery in one almost daily. While I noticed they take twice as long to charge as the GP Charger with the floating contacts, I hadn’t realized they are also twice as dangerous, perhaps it’s best to get rid of them or at least dis-assemble each one and look at the isolation distance. What would a minimum recommended distance be to pass the 5000V test?
The safety tests and specifications depends on the mains voltage, with 230VAC the distance has to be at least 4 mm through air and longer on a circuit board.
But the trafo must also have some isolations distances inside and that is impossible to see. Sometimes there is a capacitor between mains and low volt side, this capacitor must have safety rating, but on some of the cheap chargers it does not (They uses a ordinary 1000 volt capacitor).
Thanks, the obvious thing to do then is simply not use them.
Have you come across any good quality generic chargers with USB output that you have recommended in the past that you can recall?
The ML102, it is cheap and works very well.
It need an external usb power supply, there I have used the Skross and the Ioncell
I already have one of those Millar units, as well I assume the ENB would be similar.
I see that one of your better chargers, ‘Ioncell’ results came from a unit from intl-outdoor. As I plan to buy more from them in the future, I’ll see if they still have them and grab some on my next order. Thanks for the very informative and comprehensive review.
