I just thought I might add one more thing.
The quality cells will give a higher current tail cap reading than the cheap cells. They have a lower internal resistance which allows more current to flow. In return giving you more light than when using cheap cells.
the protection circuitry is the only thing that brings the tf 3k down…unprotected vs protected isn’t really a fair fight…the one I compared to was the 2600mah in the pulldown…the one you showed was right above it and was the unprotected version…the one I showed had pv after it which I assume is a protected model of the sanyo 2600…
I run panasonics mostly, but really can’t fault the trustfires that I have…I run them in my Dry and they deliver 5+ amps on a full charge…pretty impressive…
This is often true in a single cell light, but it is not always the case. Some exceptions are:
- In a light with a buck or boost driver. These are power converters and if the battery voltage drops (like a bad cell would), the battery current would increase to compensate and keep the power the same. In a properly regulating boost or buck circuit with cells at the same starting voltage, a lower tail cap current indicates a better cell.
- Lights with linear regulators may give the same drive current initially. In this case (everything else being equal), the cell that begins to give reduced current first is the weaker cell.
- There are probably others but me brain is no worky good right now… :weary:
Direct drive (unregulated emitter current) circuits are the one case where higher current will indicate a stronger cell.
Just too much inconsistency in between the good ones. I don’t trust the “fire” cells. And they don’t perform as good when looking at the overall picture. Lots of bad cells out there too. The lottery aint worth it.
On a side note. Tesla Roadster use 7000 (SEVEN THOUSAND) 18650 Panasonic cells in a battery package (for Model S ).
They offer 8 year warrany on their battery packages. The price they get are of course vital to which manufacturer they choose.
But Tesla have 3 crucial demands. High capacity, high performance combined with long lasting life. They choose Panasonic cells.
With a production of say 20.000 cars that will be 140.000.000 Panasonic cells every year!
If they deal with such numbers and need the best performance and best battery life and swear by Panasonic to give them the performance they need, then its probably good enough for me too. They have done a lot of testing for many years. For a company like Tesla the life of batteries are crucial, or else they will get warrany issues (or maybe Panasonic will get warranty issues depending on how deals are made.)
I can not say that Panasonic (or Sanyo cells) will last longer compared to Trustfire… I dont have good facts to back it up. I only have reason to assume so based on the reputation of the cells they have produced in the past and based on things like the warrany Tesla (/Panasonic?) can give on their batteries for the future.
Bang for the buck are not only what you pay and how the batteries perform on paper when they are brand new. Its also vital how many years they can perform good.
My 2 cents…
Relic38 I guess I should have been more clearer.
Yes in a buck driven light you may not notice any difference besides run time. If its a CC driver it doesn’t really care if its a quality cell as long as its voltage under the load is over the vf of the led + the needed head room for the driver.
- The linear regulators is where I noticed the biggest difference. Like a amc7135 driver. The 2800mah driver is suppose to give you 2.8 amps. When I measured with my TF they only drew 2.5a. When measured with the Sanyo’s I got just a hair over 2.8a.
I read about this many times at cpf. I never really new there was much difference until I started using quality batteries. This is not a one time test I done this has been tested several times by me over the years and by many others.
No problem, that’s why I felt that I should post to help clear things up a little.
Knowing how these things work is why I went with Sanyo cells; they hold a higher voltage during the discharge curve. The linear regulators do not drop out as early. For buck and boost drivers, they draw less current which can result in a slight improvement in efficiency (less current in the springs, wires, traces, threads, etc. means less loss there).
