Yup, this is what i was talking about, it reminds me my toilet plunger
And the most funny part is
A CLIP, yup, i gonna put it in my pocket. It will be my fav EDC light, a clip is must to have
What about something that can reach 1,49km ? 555kcd ? Hm ?
Answer is Niwalker Vostro BK-FA09S. I’ve found this @ Martin’s blog, German I’m afraid but pics are nice > https://m4dm4x.com/review-niwalker-vostro-bk-fa09s/
Ah OK I see where you are coming from, modded lights do get pricey, the type of skills and time to tune lights is just expensive. Although some of these stock lights are more expensive than a modded light based on a cheaper host like a Convoy. You might want to set a budget range. And while many are, I wouldn’t say modded always means power hungry, particularly if you are looking for throw and not lumens. I guess I spend too much time on BLF and modding lights so I’m just never impressed with the throw of stock lights.
I don't necessarily have a budget. I like all the lights!! But everyone has to have a sensible margin, as to what they want, that's pocket-able.
You know, the best of the best in that size category. Flooders to me are more common ground, where flooders with minimal spill, there's a narrow band where, there is spill for the outer perimeter, but the perimeter has less of a blend as it flows to the beam of spot. If this makes sense. My easy way to refer to it is similar beam of the Nitecore P30?
In my review i mentioned there seems to be very little difference hotspot brightness difference between a Crelant V4A and a 50% wider reflector Nitecore P30 “optimized” for throw with both containing the same XP-L HI chip, even the same tint.
I don’t have any measuring tools so its possible your correct, just subjective hotspot brightness though where did you find that number for the V4A, i have not come across any figure for it.
The V4A was from memory, but searching for ‘V4A cd’ Djozz measured 64kcd, and the specifications list it as 68kcd.
Convoy L2. 110kcd is a rough estimate. I’ve read lower and higher. My review sample was doa, after replacing the led and driver (with xpl-hi v2-3A on noctigon and 3.04A Qlite) I measured 136kcd.
As ARsee said, The L2 is indeed quite large compared to the P30.
