Interested, I hope the ? is as low as possible
Edit: just purchased one.
Interested. Thanks!
Thank you, ordered a blue one
Thanks, ordered 2 black ones.
Interested!
Interested
Still active?
I'm in for four.
slmjim
Headlight 7-Modes 140LM Rotatable 2*AAA
WHERE 140?
I did a runtime. Cheap UNI-T luxometer used, so lumens may be a bit less.
I just received mine. 10 days from Banggood to the U.S.! Nice budget headlamp. Very adjustable.
offer is active
Received my two today, 14 days from order to my door, not bad. Good news, looks like an emitter swap will be possible!
I am interested in 1/Blue.
Thanks for the photos
If I may ask, which led are you thinking to use there?
I was searching for some images of the base of the led and it doesn’t seem similar to XP leds… so it may be a bummer to an easy swap :zipper_mouth_face:
http://www.ebvnews.ru/doc16/GW_PUSRA1.PM_DURIS_P8.pdf
BTW, mine is already in the country and will probably be delivered within the next days
Mine should be arrived today, it’s with the courier now.
Can’t wait to try it!
Update:
Got it! Nice little light.
I don’t know why the spec said 140 lumens. The packaging from Banggood website said 120 lumens.
Ordered on the 3rd!
Shipped on the 10th!
Arrived on the 17th!
Not baaaad!!!
First overall impressions are good!
I was planning to install a nice tinted SST20 that I have a few left of from BlueSword. I’ve seen the data sheet and the package size is the same, just the footprint is ever so slightly different. I figured it should work. Maybe someone can chime in before I try?
Fin,
Interested in one of each color.
thanks
I never tried, hence my question about that!
Here are the mechanical dimmensions of each LED
Osram P8
Source: http://www.ebvnews.ru/doc16/GW_PUSRA1.PM_DURIS_P8.pdf
SST20
Source: https://download.luminus.com/datasheets/Luminus_SST-20-WxH_Datasheet.pdf
