Flydiver - got it. You don’t think it’s a good idea. We disagree on the merits of this project.
Swapping out a driver and led star is by no means “a LOT” of modding. It’s ho-hum for many of the folks on this forum, which is why I’m asking for their expert help. I’m interested in how it can be done, and I think there’s alot of good discussion happening around the “go for it” camp.
Luumensguy: it may be possible to get higher lumens than stock but you may not get more than 1200. The driver type is specific and you might only be able to do a resistor mod to get a little higher output. I’m guessing that the stock output is 800ish lumens. I’m also guessing that the LEDs are lattisbright and not real Crees.
You may be able to use a different driver that requires a normal off/on switch and operate the flashlight by twisting/untwisting the tailcap however, that would increase wear and tare on O rings and maybe more significantly, cause pressure changes inside the light which would not help with water resistance.
I can help with that. Twist on/off is a very normal way to operate a dive light. Decent lube and that’s no problem. The minor pressure change that this creates, which is a very small increase, in no way should affect the water resistance. Compared to water pressure it’s less than trivial. If it can’t take that, it can’t even take dunking.
