Fasttech - interesting new products - Flashlights, chargers, batteries and DIY and knives - please no discussions.
hi, does the soshine Sc-S1max v3 not do 4x 1 amp charging ? ive not got one though guys .
http://lygte-info.dk/review/Review%20Charger%20Soshine%20SC-S1max%20V3%20UK.html
Yes, which is why the SoShine has been on my wishlist. I'm wondering how many 26650's can fit at one time in the Xtar XP4.
-Garry
I recall reading somewhere i can fit 2 of them. One in either outer slot.
So it's no different than the SoShine (as far as charging 26650's - two at a time at 1.0A).
-Garry
I think it was HKJ that posted an image showing the wider spacing on the outer two bays.
XTAR wrote in their selling folder this, but I will ask my XTAR connection and will write down his answer in this post.
Here are the XTAR products, which are the most interesting in my opinion (hope the chargers will aso be available with a EU plug, because I like the US to EU adapters not to much). Most of the chargers are tested by HKJ
You save 5% if you use BLF as a coupon code:
XTAR XP1 Single Channel Lithium / Ni-MH / Ni-Cd Battery Charger $8,07 my Link - non aff-link
XTAR WP2II Dual Slots Multi-Functional Intelligent Battery Charger US plug / car charger $20,60 my Link - non aff-link
XTAR WP2S Dual Channels Intelligent Li-Ion Battery Charger US plug, similar to the WP2 II, but the USB port has 2,1A and the charger has 0,25, 0,5 and 1A $26,18 my Link - non aff-link
XTAR SP2 Dual Channels Intelligent Li-Ion Battery Charger US plug $27,43 my Link - non aff-link
XTAR VP1 Dual Channels Multi-Functional Li-Ion Battery Charger US plug $32,89 my Link - non aff-link
XTAR 16340 3.6V 600mAh (2-Pack) button top / protected, dimensions: 35mm, 16,3mm $5,36 my Link - non aff-link
XTAR 18650 3.7V 2600mAh (2-Pack) button top / protected, dimensions: 70,2mm, 18,4mm $13,86 my Link - non aff-link
XTAR 18650 3.7V 3100mAh (2-Pack) button top / protected, dimensions: 69mm, 18,5mm $21,85 my Link - non aff-link
Stop your neck from flapping in the wind.
https://www.fasttech.com/products/1/10005796/1449202-portable-multi-function-neckline-slimmer-with-3
LOL i wonder if they do a beer-belly toner ? :slight_smile:
Sure! And it’s just as effective… :wink:
Enlan EL01 for $15.43
Dimensionsus | metric
DEPTH 14 mm
HEIGHT 211 mm
WIDTH 40 mm
BLADE LENGTH 95 mm
CLOSE LENGTH 116 mm
OPEN LENGTH 211 mm
PRODUCT WEIGHT 155 g
THICKNESS 37 mm
GANZO G708 Stainless tactical for $15.61
DEPTH 18.3 mm
HEIGHT 194 mm
WIDTH 31.5 mm
BLADE LENGTH 80 mm
CLOSE LENGTH 114 mm
OPEN LENGTH 194 mm
PRODUCT WEIGHT 137 g
THICKNESS 4 mm
Gerber Myth drop point folder for $18.93
DEPTH 16 mm
HEIGHT 208 mm
WIDTH 43 mm
BLADE LENGTH 80 mm
CLOSE LENGTH 128 mm
OPEN LENGTH 208 mm
PRODUCT WEIGHT 85 g
THICKNESS 3 mm
Harnds Viper folding knife for $15.37
DEPTH 16 mm
HEIGHT 21 mm
WIDTH 30 mm
BLADE LENGTH 90 mm
CLOSE LENGTH 115 mm
OPEN LENGTH 210 mm
PRODUCT WEIGHT 160 g
THICKNESS 3 mm
Sanrenmu 7010LUC-SA stainless folder for $8.31
DEPTH 8.6 mm
HEIGHT 160 mm
WIDTH 24 mm
BLADE LENGTH 70 mm
CLOSE LENGTH 95 mm
OPEN LENGTH 165 mm
PRODUCT WEIGHT 89 g
THICKNESS 2.5 mm
Huge CRKT M21-14SFG folder for $13.43
DEPTH 18.7 mm
HEIGHT 234 mm
WIDTH 44 mm
BLADE LENGTH 100 mm
CLOSE LENGTH 134 mm
OPEN LENGTH 234 mm
PRODUCT WEIGHT 171 g
THICKNESS 37 mm
I actually thought FT might be a bit cheaper, its only 4 cents cheaper than Exduct and $1.44 more than the lowest eBay price.
Although its good they stock it, they might price match other vendors now that they have it.
Some other knives (don't think, that they are genuine) and a multitool:
Jeep multitool, 6-in-1 Pocket Tool silver with a knife, pliers, wrench for $12,12. My link - non-aff-link
CRKT Stainless Steel Outdoor Folding Knife black / 9.5cm blade (looks like a CRKT M16) $20,46. My link - non-aff-link
Mini Stainless Steel Outdoor Folding Knife black / 4.5cm blade - fake Böker Plus Subcom $4,51. My link - non-aff-link
SOG Stainless Steel Outdoor Folding Knife silver / 6cm blade $7,35. My link - non-aff-link
That Jeep multi tool looks interesting. Just the thing for removing the hasp on our backcountry work cabins when I arrive after a 20km hike and contemplate a night on the porch and uncooked freeze dried food after I discover I forgot my keys. Weight seems not too bad for an item that bulky (at 147g I’m thinking perhaps they got it wrong as that’s the same weight as my Leatherman Skeletool CX). I wonder how far the jaws open on that wrench? I also wonder who makes these ’clones” (after all it might be a clone from the same factory that makes the originals no?). If it were from a Ganzo factory I assume the quality would be not so bad?
Edit: just found a review online, it holds up to an 11mm bolt head.
Someone should ship Swedish sandvik 12c27 steel to this Chinese manufacturers…
I don’t know for you guys but this is best steel if you ask me. It holds edge 10 times better than my navy or ganzo knifes.
I would not mind if price of their knifes exceeds few bucks if this steel used.
Even if you shipped a better steel, I wouldn’t count on it having a good heat treatment. 8Cr13MoV is not terrible if treated properly.
I didn’t realize the difference between those was that significant. Is it actually a factor of 10X, or was that more of an allegorical figure (as opposed to an empirical figure), meant to illustrate that 12c27 subjectively seems to be quite a bit better than 8Cr13MoV?
Twenty something new airguns, and a couple of Weaver rifle scopes in the New Arrivals. The G20 pistol / 1911 replica looks like fun.
According to my experience 12c27 sandvik is much much better steel than 8Cr13MoV… Is it 10× better? I think it is.
Get it and then you will see what I talking about. I recommend this for start: http://www.ebay.com/itm/Mora-of-Sweden-11602-2010MG-Forest-Bushcraft-Steel-Knife-Blade-Morakniv-/370838931847?pt=Collectible_Knives&hash=item5657b90987
You will be surprised what this steel can do.
When you use those cheap china blades on skinning jobs they tend to dull rather quickly. You need to use sharpener all the time. With sandvik I can skin 5 roebucks without sharpening.
But if you’ll use them for self defense or paper cutting than no problem. They are sharp enough for self-defense if you know what I mean :wink:
It’s funny you should mention that Mora, because I have been giving serious consideration to grabbing one. I’d like you opinion on this Hultifors knife as I am close to the seller and could grab it with no shipping.
I also noticed this Mora the other day. That I was thinking about.
As an aside, I am allowed a knife, and also a multitool, every 3 years paid for by my employer. I never bothered with the knife because I have so many Chinese knives. But last week I was getting a new Leatherman Skeletool as I got tired of the weight of my Leatherman Wave. I saw a CRKT 2865E in the case so I decided I may as well grab one (paid for by my allowance) and perhaps give it to a co-worker that had lost his work knife in the field.
Apparently the steel is 1.4116 stainless. I subsequently learned at $84.00 it was a total rip off price. The blade says Kommer 30-30 on it. But just handling the knife it feels real nice in the hand, it does not have a clip (which I like but has caused me to lose a Ganzo and a Bee in the past two months), but now I’m thinking about keeping it, especially after this talk about how much better good steel can be. How does 1.4116 stainless stack up?
The Hultafors is a great value knife, as is the Mora. I have a Hultafors Heavy Duty knife and it is tough as they come, you would have to be doing something stupid to break one. They all punch far above their weight and the one you’re looking at,the Craftsman is no different. They come very sharp and stay that way for a good length of time, unless you are sharpening bricks or something.
There are a few videos on you tube—
EDIT………….
4116 Is a Krupp steel. I have a Cold steel Tanto Lite with this blade-steel and it’s not bad, Cold Steel uses it for a lot of their less expensive blades so being Cold Steel it has to put up with a lot.
I’ve never really hard used it but after a few gardening tasks it held up O.K. not needed sharpening just a quick stropping.
