I ordered a few of the 12mm when they listed them, would really like to wake up and find same on 12mm Noctigons some day.
nice option on those 25mm and 32mm… but why all NW?
Enlan EL-02B (one of my favorite knives). Axislock, stonewashed blade 92mm blade, pocket clip and G10 handle. Price: $13,12 My link - Non Aff-link
Enlan Bee EL-01AB Stainless Steel Half Serrated Folding Knife black / 94mm blade / w/ pocket clip. I know, that many people don't like serrations, but the price is really good if a half serrated blade is acceptable.
Price: $12,64 My link - Non Aff-link
Sanrenmu 614 Stainless Steel Skeletonized EDC Folding Knife, 55mm blade Price: $7,01 (silver) $7,23 (black) My link - Non Aff-link
V8-4 Dual USB PCB Board + Plastic Enclosure for Power Bank DIY black / 1-4*18650 batteries required and are not included! Available in black and white - and there are also a 1-2* 18650 version in white ($14,11). Input voltage & current: DC 5V / 2A. Output voltage & current: DC 5V / 1A, DC 5V / 2.1A. Work with flattop and button top (don't know the max. length, but I ask and will included the information here). Dimensions: 130 x 84 x 26,5mm. Price for the 4* 18650 version: $17,23 My link - Non Aff-link
Turtle Shell "12000mAh" actual capacity 6000mAh Dual USB External Battery Charger Power Bank available in a few colors: Army green / black, white / pink with LED flashlight. Input voltage & current: DC 5V / 1A. Output voltage & current:DC 5V / 1A, DC 5V / 2A. Dimesnsiobs: 106,6 x 75,2 x 25,4mm. Price: $14,15 My link - Non Aff-link
FT lisated a lot of these LED modules in the last two days: 6, 14, 18, 24, 30 or 36 LEDs, different diameters 32-100mm, 2800-3300K, 3000-3500K or 6000-6500K. Price range $1,78-3,83
You can select all, if you enter one of product page for example these
30-LED 15W 1300LM 3000-3500K Ceiling Lamp Light Source Module 2P15S / diameter 88mm / center opening 6mm. Price: $2,99 My link - Non Aff-link
Operating Voltage 48 -volt
Thanks for the update. I got really excited and was about to jump all over them, and then noticed they were just 2 and 3 Watt :_( . Good for anyone that was looking to replace their FRS radio however.
Interesting looking knife. On the site they refer to it as a ‘monolock’? Looks like a frame lock to me…?
[quote=Buwuve]
I had requested the UV5R, though I don’t know what wattage it is.
I had been eyeballing that knive. However I did buy one of the $5.00 Rimei 5806 knives and I liked it so much I ordered 5 more, so I thought I should resist the temptation to get that one as well, at least for now.
Chloe, I gave in and after doing some reading on eHam and elsewhere, ordered one of the 3W Baofeng units just to test and play with, and I did note the power plug will not work for me but that is minor. Your post has had me off on a tangent for the last couple of hours. Among other things, I submitted a request that Fasttech order some of the 5W Wouxun KG-UVD1P radios, and it also led me to a Blog where the US Wouxun dealer apparently dropped them in favour of a radio called an ‘AnyTone AT-3318UV-A’ which he claimed is even better, but I cannot seem to find on Ali or eBay.
Here is a good site I stumbled across that should give good info on that, and other similar ones:
So you must get 2 sets of either one to get 2 radios to talk between?
No sets like 2 radios + one charger?
I just noticed the same MRsDNF!!
Here it is, but please don't disscuss advantages of the 3 or 5 Watt product in this thread. Open a new, edit one of your posts here and write down the link to the thread. Everyone else, who is interested in could find all information in one thread. Thank you :)
BaoFeng UV-5R 5W 136~174MHz / 400~520MHz Dual Band Two-Way Radio black / 128-channel / 1*1800mAh battery / US plug adapter. $43,03 My link - non aff link
BaoFeng BF-888S 5W 400~470MHz Two-Way Radio black / 16-channel / 1*1500mAh battery / US plug charger. $22,03 My link - non aff link
Maybe useful for a DIY project:
Titanized High Speed Steel Drill Bit in different sizes: 4-32mm, 4-20mm, 4-12mm. You can get all three for $20,66 each separate for $4,19, $6,79, $ 11,05 My Link - non aff-link
Edit now a few more. Same size, but cheaper (all three in a box) for $17,80 My link
Now FT has a lot of Tekut knives. Here are only a few. Tekut uses 7Cr17MoV steel for the knives and not the 8Cr13MoV like Sanrenmu or Enlan. SOG uses this steel in a few knives.
I don't own a Tekut and would prefer a SRM if the design is similar, because SRM would be cheaper and I like the quality of SRM. But Tkut have some designs, which looks interesting.
TEKUT LK4120 Fire Snake Stainless Steel Folding Knife 62mm blade.Closed length 89mm, opened 151mm, blade thickness 2,2mm, weight 59g. Price $11,73 , my link - non aff-link
TEKUT LK4118 PENGU Stainless Steel Folding Knife 70mm blade / blue.Closed length 99mm, opened 169mm, blade thickness 2,4mm, weight 64g. Price $9,39 , my link - non aff-link
The next knives are available in a few different styles. In blue, black or rainbow colored, with a 65mm balde or sthe small version with a 43mm blade.
TEKUT LK5063A/B/C Pecker Stainless Steel Folding Knife 65mm blade (Pecker mini 43mm).Closed length 93mm (mini 69mm), opened 158mm (mini 112mm), blade thickness 2mm (mini 1,5mm). Price $8,89 (mini $6,97 ) , my link - non aff-link
And two more
TEKUT LK4105 Chopper Stainless Steel Folding Knife 56mm blade / black. Closed length 89mm, opened 135mm, blade thickness 1,8mm, weight 50g. Price $7,82 , my link - non aff-link
TEKUT LK5035A Fairy Stainless Steel Folding Knife 71mm blade / rainbow colorClosed length 100mm, opened 171mm, blade thickness 2,2mm, weight 87g. Price $8,58 , my link - non aff-link
You forgot "vaping gear"
That UV-5R is a decent little rig, I have a Puxing PX-777+ and a MTC UV-X4 (which I believe is the Beofeng UV-3R) and they work rather well..on the dual band you can program in both the non-regulated (you wont need a license) GRMS/FRS [limited to .5 watts] and MURS frequencies and if you are a HAMer they actually have pretty good range with DIY antennas, and can use a myriad of repeaters
You don't need a license to listen...only Transmit...
During an emergency the HAMers come out of the woodwork..and even though everything else is down...trust me...they ARE still talking
Now FT add some more flashlights.
Convoy L5 1*Cree XM-L2 U2-1A 2-Group 3/5-Mode LED Flashlight black / 1-2*18650 / 1-2*26650 / LD29 driver / 2600mAh. Price with BLF: $38,13. My Link - non Aff-link
16. Jan. FT add some more LEDs: T4-7A, T5-5B, T6-4C, T6-3B.
XINTD X3 1*Cree 1000LM Warm White LED Flashlight dark grey / 7135*8 / 1*18650 / 1*26650 / 3*AA available with different LEDs:
XM-L2, 5-Mode (all other shops wrote 2 groups: 3 [low, mid, high] and 5 mode) ->I will ask, T4-7A, T5-5B, T6-3B, T6-4C , U2-1A Price with BLF $32,56-34,08 My link - non aff-link
Why why WHY can’t they make a proper quality 3xAA holder instead of this 0.50$ piece of you know what, starts with “s”!!!
Unfortunately even the seller with nice quality holders on pictures is shipping X3 with cheap plastic one. 5 mode only and the same price as the one from banggood with 2 groups driver. Intl-outdoor has much nicer modes selection with less bright lower modes (2% and 25% instead of 5 and 40%) but is it worth $15 extra?
About L5 - description says XM-L2 U2 1A, picture shows warm white emitter.
