Skilhunt E3a is the only only twisty I trust not to unscrew. That’s a two hander, or very strong fingers to twist.
Budget, no doubt Wurkkos TS10 on an offer. I picked up 2 orange ones for $10 each, had to get 2 to push the free shipping. Really a bargain, ready to go with 14500 batteries included.
I’m physically common and may operate with E3A by a single hand. It’s useful when during walking you pass parts with different ambient illumination where the flashlight is not needed constantly.
What may differ.
Resin/silicon ring near body’s thread has 2 possible positions. From the factory it was (mb by a mistake) situated closer to front and I shifted it closer to back side.
I used a toothpick to place silicone grease on that resin ring. In case this will not be enough, - it’s possibly to place the grease on colored part of the thread to make the twisting easier. Though, a grease has a thickness itself and hypothetically much of it may increase the needed force to turn. Silicone oils with low viscosity make small thickness layers.
On the flashlight I have 2 metal rings: small one from the initial accessories, joined with 2 cm (of inner diameter) from a random keychain. That bigger ring is placed on annular finger, what helps to hold and not to drop the flashlight occasionally.
Then:
May exist individual product variations. As example, one “slate blue” (those also have differing anodization) from the start turned easier than an examplar with orange color.
Resin ring after many turns becomes thiner and hence gives lesser rubbing force. Other parts get a lapping during usage.
I have an Energizer and a Coast headlamp and I kind of hate both of them because they burn their batteries too fast.
I bought both of them before I knew too much about flashlights, so I did not know what a constant current driver was.
I’ve educated myself flashlights in the last 6 years or so, plus I have a lot more experience
Now I do not even look at a flashlight unless it comes with a constant current driver
I’ve also gone away from small capacity lights anything under 3500 mah, is not good enough for me.
I’ve also learned through experience that anything plastic cannot hold even 350 lumens for more than 2 minutes, which is garbage
The only budget light that did not totally suck has been Maglite mini pro, but even that one is disappointing cause it cannot hold its brightness for long, plus it’s over $20 now at my local Wally world.
I consider Convoy to be the cheapest budget light that doesn’t suck, but I really don’t mind paying more for something like Acebeam or Weltool in order to get better quality and runtime.
Convoy m21 series are great, even the S2+ has great runtime but unfortunately mostly on the eco,low, and medium low modes
Replying to an old post I know but I think it’s worth noting that someone on Reddit dropped one of those Ozark Trail lights with an 18650 battery installed, the battery shorted and the light melted.
