I like the design of the z8 very much, but have not bought one because the XML is a very poor and inefficient thrower in a small aspheric. If a custom light could be arranged with a (neutral) XPG2 (smaller die, tighter beam), I'm in!! Oh, and make the UI like the BLF-mini.
XP-G2 beam angle is 115 degrees and XP-E2 is 110 degrees. The original XP-E is 115 degrees. Only the XP-G has the same beam angle as the XM-L @ 125 degrees.
I would be in. But probably not for that spec tbh. I’d rather CW and U2 over NW and T6. Also really couldn’t care for AA support. Would also prefer just two modes High and mid high. No lows at all, I have no use or need for low and get fed up scrolling through them.
I rarely use low on any of my lights, and never use moonlight modes if they are present, but you never know the circumstances you might end up in one day. Having a usable low with a 7 day runtime, or a moonlight mode that lasts for an order of magnitude longer, might end up being a godsend.
Well, to some extent it also matters if the product is good if not great. We’ve actually some experience with this over many BLF edition lights, all of which have been decent, but none that carried onto the go to recommendation for a category. Everyone has different goals, but if I were doing this, my goal would be to create the iphone so to speak of flashlights. Not just something that sells a few to a niche crowd but a sustainable product.
For example, the z8 looks ok, but I think the A3 or T2 with the right specs has the potential to sell thousands or more, and be part of a product lineup that define the category.
I mean, as flashoholics we all know the many follies that manufactures make again and again: shitty memory, shitty modes, shitty tints, strobes, and the list goes on for trivial to correct design flaws. If someone would just create a marginally different lineup which avoids these incredibly dumb mistakes they’re pretty much guaranteed long term success.
Then the problem is to find a fitting driver…
So a custom version of the Z8 which is a nice and very small zoomie host which is waterproof would be definitely what I need. The bicolor style is quite a bit strange but I would like to have a powerful 14500 XML with zoom…
I like agenthex’s proposal of a t2, but fitted with a mode selectable driver, similar interface to this one:-
Ie, using the clicky, you can either have mediumlow, medium high or next mode which is moonlight-high ramping.
AA/14500 support I’m less interested in as I can carry an 18650 light in any of my trousers, I’d have to buy AA/14500 cells.
Blinkies, manufacturer’s, either say no or hide them, people who want a blinky, tend to want it straight away - self defense springs to mind, cyclists want a much slower frequency, most don’t want them at all, its just a gimmick mode.
To me, a side switch pocketable host with a user programmable driver and a well chosen emmitter/reflector combination is a much more attractive proposal than a flood to throw host. But that’s just me.
Count me out of the z8, it just won’t ever make me happy, but good luck with the proposal none the less.
