* NANJG 105C Diagram
* -| |- VCC
* Star 4 -| |- Voltage ADC
* Star 3 -| |- PWM
* GND -| |- Star 2
- CPU speed is 4.8Mhz without the 8x divider when low fuse is 0x75
- define F_CPU 4800000 CPU: 4.8MHz PWM: 9.4kHz ####### use low fuse: 0x75 #######
/8 PWM: 1.176kHz ####### use low fuse: 0x65 #######
- define F_CPU 9600000 CPU: 9.6MHz PWM: 19kHz ####### use low fuse: 0x7a #######
/8 PWM: 2.4kHz ####### use low fuse: 0x6a #######
- Above PWM speeds are for phase-correct PWM. This program uses Fast-PWM, which when the CPU is 4.8MHz will be 18.75 kHz
- FUSES
I use these fuse settings
Low: 0x75
High: 0xff
- STARS
Star 2 = Moon if connected
Star 3 = H-L if connected, L-H if not
Star 4 = Memory if not connected
- VOLTAGE
Resistor values for voltage divider (reference BLF-VLD README for more info)
Reference voltage can be anywhere from 1.0 to 1.2, so this cannot be all that accurate
VCC
Vd (~.25 v drop from protection diode)
1912 (R1 19,100 ohms)
|---- PB2 from MCU
4701 (R2 4,700 ohms)
GND
ADC = ((V_bat - V_diode) * R2 * 255) / ((R1 + R2 ) * V_ref)
125 = ((3.0 - .25 ) * 4700 * 255) / ((19100 + 4700) * 1.1 )
121 = ((2.9 - .25 ) * 4700 * 255) / ((19100 + 4700) * 1.1 )
Well 125 and 121 were too close, so it shut off right after lowering to low mode, so I went with
130 and 120
To find out what value to use, plug in the target voltage (V) to this equation
value = (V * 4700 * 255) / (23800 * 1.1)
#define F_CPU 4800000UL
- Settings to modify per driver
#define VOLTAGE_MON // Comment out to disable
#define MODE_MOON 1 // Can comment out to remove mode, but should be set through soldering stars
#define MODE_1 8 // Can comment out to remove mode
#define MODE_2 75 // Can comment out to remove mode
#define MODE_TURBO 255 // Can comment out to remove mode
#define TURBO_TIMEOUT 37 // How many WTD ticks before before dropping down (.5 sec each)
#define WDT_TIMEOUT 2 // Number of WTD ticks before mode is saved (.5 sec each)
#define ADC_LOW 130 // When do we start ramping
#define ADC_CRIT 120 // When do we shut the light off
#ifdef MODE_TURBO
#undef MODE_HIGH
#define MODE_HIGH MODE_HIGH_W_TURBO
#endif
//#include <avr/pgmspace.h>
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <avr/wdt.h>
#include <avr/eeprom.h>
#include <avr/sleep.h>
//#include <avr/power.h>
#define STAR2_PIN PB0
#define STAR3_PIN PB4
#define STAR4_PIN PB3
#define PWM_PIN PB1
#define VOLTAGE_PIN PB2
#define ADC_CHANNEL 0x01 // MUX 01 corresponds with PB2
#define ADC_DIDR ADC1D // Digital input disable bit corresponding with PB2
#define ADC_PRSCL 0x06 // clk/64
#define PWM_LVL OCR0B // OCR0B is the output compare register for PB1
// Mode storage
uint8_t eepos = 0;
uint8_t eep[32];
uint8_t memory = 0;
// Modes (gets set when the light starts up based on stars)
static uint8_t modes[10]; // Don't need 10, but keeping it high enough to handle all
volatile uint8_t mode_idx = 0;
int mode_dir = 0; // 1 or -1. Determined when checking stars. Do we increase or decrease the idx when moving up to a higher mode.
uint8_t mode_cnt = 0;
uint8_t lowbatt_cnt = 0;
void store_mode_idx(uint8_t lvl) { //central method for writing (with wear leveling)
uint8_t oldpos=eepos;
eepos=(eepos+1)&31; //wear leveling, use next cell
// Write the current mode
EEARL=eepos; EEDR=lvl; EECR=32+4; EECR=32+4+2; //WRITE //32:write only (no erase) 4:enable 2:go
while(EECR & 2); //wait for completion
// Erase the last mode
EEARL=oldpos; EECR=16+4; EECR=16+4+2; //ERASE //16:erase only (no write) 4:enable 2:go
inline void read_mode_idx() {
eeprom_read_block(&eep, 0, 32);
while((eep[eepos] == 0xff) && (eepos < 32)) eepos++;
if (eepos < 32) mode_idx = eep[eepos];//&0x10; What the?
else eepos=0;
inline void next_mode() {
if (mode_idx == 0 && mode_dir == -1) {
// Wrap around
mode_idx = mode_cnt - 1;
} else {
mode_idx += mode_dir;
if (mode_idx > (mode_cnt - 1)) {
// Wrap around
mode_idx = 0;
inline void WDT_on() {
// Setup watchdog timer to only interrupt, not reset, every 500ms.
cli(); // Disable interrupts
wdt_reset(); // Reset the WDT
WDTCR |= (1<<WDCE) | (1<<WDE); // Start timed sequence
WDTCR = (1<<WDTIE) | (1<<WDP2) | (1<<WDP0); // Enable interrupt every 500ms
sei(); // Enable interrupts
inline void WDT_off()
MCUSR &= ~(1<<WDRF); // Clear Watchdog reset flag
WDTCR = 0x00; // Disable WDT
inline void ADC_on() {
ADMUX = (1 << REFS0) | (1 << ADLAR) | ADC_CHANNEL; // 1.1v reference, left-adjust, ADC1/PB2
DIDR0 |= (1 << ADC_DIDR); // disable digital input on ADC pin to reduce power consumption
ADCSRA = (1 << ADEN ) | (1 << ADSC ) | ADC_PRSCL; // enable, start, prescale
inline void ADC_off() {
ADCSRA &= ~(1<<7); //ADC off
#ifdef VOLTAGE_MON
uint8_t low_voltage(uint8_t voltage_val) {
// Start conversion
ADCSRA |= (1 << ADSC);
// Wait for completion
while (ADCSRA & (1 << ADSC));
// See if voltage is lower than what we were looking for
if (ADCH < voltage_val) {
// See if it's been low for a while
if (++lowbatt_cnt > 8) {
lowbatt_cnt = 0;
return 1;
} else {
lowbatt_cnt = 0;
return 0;
#endif
ISR(WDT_vect) {
static uint8_t ticks = 0;
if (ticks < 255) ticks++;
if (ticks == WDT_TIMEOUT) {
if (memory) {
store_mode_idx(mode_idx);
} else {
// Reset the mode to the start for next time
store_mode_idx((mode_dir == 1) ? 0 : (mode_cnt - 1));
#ifdef MODE_TURBO
//} else if (ticks == TURBO_TIMEOUT && modes[mode_idx] == MODE_TURBO) { // Doesn't make any sense why this doesn't work
} else if (ticks == TURBO_TIMEOUT && mode_idx == (mode_cnt - 1)) {
// Turbo mode is always at end
PWM_LVL =185;
#endif
int main(void)
// All ports default to input, but turn pull-up resistors on for the stars (not the ADC input! Made that mistake already)
PORTB = (1 << STAR2_PIN) | (1 << STAR3_PIN) | (1 << STAR4_PIN);
// Set PWM pin to output
DDRB = (1 << PWM_PIN);
// Set timer to do PWM for correct output pin and set prescaler timing
TCCR0A = 0x21; // phase corrected PWM is 0x21 for PB1, fast-PWM is 0x23
TCCR0B = 0x01; // pre-scaler for timer (1 => 1, 2 => 8, 3 => 64...)
// Turn features on or off as needed
#ifdef VOLTAGE_MON
ADC_on();
#else
ADC_off();
#endif
ACSR |= (1<<7); //AC off
// Load up the modes based on stars
// Always load up the modes array in order of lowest to highest mode
// 0 being low for soldered, 1 for pulled-up for not soldered
// Moon (stock is 1 then 0)
#ifdef MODE_MOON
if ((PINB & (1 << STAR2_PIN))> 0) { // Stock is ==, ( > for moon default to on, soldering star will disable moon)
modes[mode_cnt++] = MODE_MOON;
#endif
#ifdef MODE_1
modes[mode_cnt++] = MODE_1;
#endif
#ifdef MODE_2
modes[mode_cnt++] = MODE_2;
#endif
#ifdef MODE_TURBO
modes[mode_cnt++] = MODE_TURBO;
#endif
if ((PINB & (1 << STAR3_PIN)) == 0) {
// High to Low
mode_dir = -1;
} else {
mode_dir = 1;
// Not soldered (1) should disable memory
memory = ((PINB & (1 << STAR4_PIN)) > 0 ) ? 0 : 1; //to disable momory without soldering star use ? 0: 1; (stock is ? 1 : 0;)
// Enable sleep mode set to Idle that will be triggered by the sleep_mode() command.
// Will allow us to go idle between WDT interrupts
set_sleep_mode(SLEEP_MODE_IDLE);
// Determine what mode we should fire up
// Read the last mode that was saved
read_mode_idx();
if (mode_idx&0x10) {
// Indicates we did a short press last time, go to the next mode
// Remove short press indicator first
mode_idx &= 0x0f;
next_mode(); // Will handle wrap arounds
} else {
// Didn't have a short press, keep the same mode
// Store mode with short press indicator
store_mode_idx(mode_idx|0x10);
WDT_on();
// Now just fire up the mode
PWM_LVL = modes[mode_idx];
uint8_t i = 0;
uint8_t hold_pwm;
while(1) {
#ifdef VOLTAGE_MON
if (low_voltage(ADC_LOW)) {
// We need to go to a lower level
if (mode_idx == 0 && PWM_LVL <= modes[mode_idx]) {
// Can't go any lower than the lowest mode
// Wait until we hit the critical level before flashing 10 times and turning off
while (!low_voltage(ADC_CRIT));
i = 0;
while (i++<10) {
PWM_LVL = 0;
_delay_ms(250);
PWM_LVL = modes[0];
_delay_ms(500);
// Turn off the light
PWM_LVL = 0;
// Disable WDT so it doesn't wake us up
WDT_off();
// Power down as many components as possible
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_mode();
} else {
// Flash 3 times before lowering
hold_pwm = PWM_LVL;
i = 0;
while (i++<3) {
PWM_LVL = 0;
_delay_ms(250);
PWM_LVL = hold_pwm;
_delay_ms(500);
// Lower the mode by half, but don't go below lowest level
if ((PWM_LVL >> 1) < modes[0]) {
PWM_LVL = modes[0];
mode_idx = 0;
} else {
PWM_LVL = (PWM_LVL >> 1);
// See if we should change the current mode level if we've gone under the current mode.
if (PWM_LVL < modes[mode_idx]) {
// Lower our recorded mode
mode_idx–;
// Wait 3 seconds before lowering the level again
_delay_ms(3000);
#endif
sleep_mode();
return 0; // Standard Return Code
