Hey all. I’ve successfully updated my ts10 and sp10 Pro with new firmware.
I do have an sc21 pro I’d like to update to anduril 2.
So my question is, can I just use an Emisar programming adapter? If I remove the pogo pin board, I have a female dupont connector. Can I just solder wires to the light pads and plug them.into the connector and use avrdude standard commands to flash the firmware?
If so. What pads and connector holes /pins do I need to connect?
I have a 3 pin programmer for the sp10/ts10. Can I just connect the wires as per the post linked? I thought the sc21 needed 5v. Is it the same voltage as the ts10?
