I have a problem with one of the eight fet + 1 drivers that i built. All of them are running the blf a6 firmware but one driver i canāt get to the soft config mode (blink where i have to select the 2nd group and memory mode). It just continuously goes to the next mode after 15 or more taps. I donāt know if itās a bug in the firmwware but all of my drivers are using the same firmware and this is the only one that is having that problem so maybe not firmware. May itās the mcu? or the otc?
IĀ“m searching for a FW similar to TKs STAR_momentary (which I use atm), but with the possibility to switch off faster. I believe I will like dth_Momentary_v1_1 but I need also dual PWM output.
Any ideas?
BTW IĀ“m not familiar in programming, just able to change mode values and flashing to driver.
Itās not difficult to change STAR (not TKās btw) so that a long(er/ish) press goes to off instead of going backwards. Thatās what I use. Short press always goes forward, long press from off goes to turbo, long press from on turns off.
I can upload the code I used when I get home tonight, but someone else might be able to do it sooner. It really is a simple change, just part of one line if I remember correctly.
Itās just a small step toward giving it a more normal code layout. Putting everything in one file is pretty unusual, and frowned on in most software development. Instead of using a single code file to represent the state of a project (like saving the build for a specific light), snapshots are more often taken in the form of a code branch or repository tag or a tarball or some other complete snapshot of the entire project.
Soā¦ Common functions, things which donāt usually change from project to project, were moved into shared headers. When one project gets an improvement to these bits, all the others benefit too. The individual projects have less boilerplate code and focus more on the parts which make them unique. And if thereās a common component you like to do differently (such as hardware calibration), you can swap out one file and itāll apply to every project automatically.
I limited this to only my directory though, since other people manage their code in different ways. And I added ātk-ā to the beginning of each file to avoid name collisions. C doesnāt have real namespaces, so I basically kludged one together in flat space instead.
Iāve still tried to avoid a lot of typical C idioms though, like depending on a specific build system or external libraries or anything else which makes it significantly harder to use in WinAVR or OSX. These projects are still simple enough to be manageable without a massive complex internal structure.
Oh, right. I tried a whole lot of different code while making the soft start ramp-up/down code, and it looks like I missed a few things when cleaning it up afterward. You could also make the ramp slower by increasing the number of steps instead of the delay between steps. This way itād be smoother.
On some later firmware, the same code should be able to provide smooth transitions between levels on an e-switch lightā¦ but that ability isnāt really used much in bistro.
I just did a quick check, and I donāt think anything in the repository matches all of the following:
e-switch
dual PWM
single-click off
attiny13a
I see everything except tiny13 in one of Tom Eās projects, and everything except dual PWM in one of my projects, and everything except single-click off in JonnyCās codeā¦ but nothing with all of them in one place. Unless I missed something.
That sounds like itās definitely a hardware difference. You can measure some hardware traits using the files under ToyKeeper/battcheck/* , but thatās just one option.
One possibility is that maybe the fast_presses variable on that exact MCU happens to decay to a useless value. This would be rare, but is possible. You could try changing around the order of variable definitions to maybe align that with a different part of RAMā¦ or try dumping out its value on boot in order to check if itās even relevant.
Anyway, itās hard to say for sure what the issue is.
The one in the post is the most recent version, I have it installed in the S8 in my sig line. I was going to ask though, can one of you wizards take a look at the LVP code? Iāve experienced some strange behavior that I havenāt totally found a pattern for. Itās almost like mode cycling stops working when LVP is kicking in. Like youāll be in turbo/fet mode, lvp will step down to medium, then you can jump back up to turbo, but you canāt cycle past turbo to low. No matter how many āshort pressesā you do it stays in turbo until lvp starts to step it down again.
Yes, I couldnāt find a matching FW too, thatās why I was asking.
But after the changes Iām satisfied with it so far. The next time the light is opened Iām going to set the long press to about .3s as well. And delete the first mode which is off. I think pdās solution should be the best. BTW then it is exactly the same UI that Nitecore is using e.g. in their HC30.
The only thing Iām not happy so far is that the turbo stepdown is happening in PWM-channel 1 only (where are my AMCs) and not in PWM-channel 2 (where is the FET). This has to be changed but I want to find out myself first. If I canāt do it I will ask again.
Ok firmware wizards, I canāt remember if I have asked this before or not. Iām looking for a firmware to use in a dual-switch light. Iāll list what Iām looking for, and hopefully thereās already something close or a more advanced FW that I can dumb down or something. If it runs on a 13 thatās preferred, but I could use a 25 or 85 if need be.
- on/off by tail power switch only
ā- always comes back on in last mode
- side switch changes modes
ā- click forward, hold for backward
precise control of two pwm channels
Thatās the main stuff, other nice things would be a shortcut to a certain mode by holding the side switch while applying power, or double click then hold enters a second mode group.
