✌ FREEME - ASTROLUX EC01 SST40 XHP50B-3V Andúril 21700/ 18650 Flashlight >>> Deal is ALIVE!!!
I would like a code, too, please.
Thank you. [quote=Kennyboy] Ordered thanks freeme [/quote]
Hi Freeme - Please also kindly send me a code.
Also, do you think this EC01 could have an edition in any special material. Something like the Cooper/Brass C8 that they’ve done. Or even better in Ti or SS.
I understand this LED is quite floody; will there be any other LED options for making this a better Pocket Thrower.
All the best and stay well!
SST40 5000K would be much more interesting option for more balanced beam. Not to mention XHP50.2. nasty green corona.
When we going to see the EC03? Or why not an EC04 to be a little bit different from other lights coming out
Design is more or less ready but launch date might have to push back due to current situation.
hi, do you know where i can find the original firmware for EC01?
[♛ Group Buy] ASTROLUX EC03 3*CREE XHP50B-3V 6700lm BLF Andúril 21700/ 18650 Flashlight >>> Interest Check
Hi Freeme, can you send me the discount code for the 5000k, please?.
Thanks. Regards.
Sure. If it is expired, please refer to https://www.1thedeals.com/product/astrolux-ec01-xhp50b-3v-3500lm-cw-21700-18650-usb-c-rechargeable-flashlight/
Hi
which batterie i should use for the astrolux ec01? The Batterie needs to be protected.
If 21700, I can recommend Samsung 40T
If 18650, Sony VTC6 or Samsung 30Q.I have both, but a little bit better results with the Sony
All these batteries are unprotected
Any advice for a protecd?
Is there a specific reason you require protected ? If running protected wont be hit the highest outputs capable by the light as well as probably tripping the protection on the cell.
Yeah I’m realy scared about the whole situation with these unprotected batteries. I’m not quite sure if they can explode or not.
freeme, could you please send me a code for the ec01 5000k version and ec03? Thanks.
Also, do you know when there will be more stock? I saw that only the US has them in stock which is also more expensive.
Modern li-ion batteries have many safety features built right in. Most of us carry cell phones and other devices in our pockets every day that use li-ion cells. It’s not like having a protection circuit right on the cell somehow fundamentally changes the amount of energy they contain.
That said, I trust the protection circuity and logic on quality flashlights more than the ones installed on protected cells. The only problem I’ve had with a li-ion battery in years and years of use was a protection circuit on an 18650 randomly shorting out and melting a bunch of the wrapper. They are added by resellers and vary greatly in quality and safety - the original cell manufacturers do NOT offer protected cells.
My protected 21700 is much to long for my EC01. Only a protected 18650 like Imalent MRB186 P30 (max. 15 Ampere) would fit in EC01.
u shouldnt run this kind of lights if u are scared of running it with non protected batteries high drain, if u know what u are doing and using good quality battery there is no need to worry.
I would like the code please.
