Ordered, thanks.
I wonder if Convoy’s 21700 button top adapter would fit in this model. Banggood should copy it
Interested.
Depending on the review.
Will wait for Tom E’s review. ![]()
It looks similar with Convoy 3x21a, which I have, as well as Sofirn Q8 Pro, which I am waiting to buy during 11/11 Sale.
Need a special reason to go for this Astrolux EC06.
Hi freeme,
better this or Haikelite HK07?
Depends. The HL should be brighter (7 LED's), but it's only 3 18650's, not 21700, and the HL is not using Anduril and weighs much more than the EC06, 492g --> 683g. The HK07 does have a nice SS bezel which I like, but I'm thinking the HK07's claim of 23K lumens is exaggerated, while the EC06's claims are much more realistic. They both seem to have pretty good specs on the USB-C charging/power bank functions.
For me, I'd definitely go with the EC06 because of Anduril2, plus the 21700's, plus the lighter weight, but certainly there's savings in weight from not having the SS bezel. Also like the extra throw the EC06 should have because of the wider head diam and less LED's (spec'd to have more throw).
Of course how the beams look is important, and not sure we have much info on that yet.
But for the EC06, I would like to see an SS bezel option, and the cap Simon makes for triple 21700 flat tops would make this light a whole lot better for battery compatibility. I ordered a couple extra triple 21700 flat top adapters from Simon, so I can easily test if it will work on this light. I found it does work on other triple 21700 lights, not just the 3X21A. Wish the EC06 would come with it, or made available. Not sure if Simon would generally sell these adapters. I had a busted up one so the ones I ordered from Simon were really a replacement, and by request.
Update: just realized the EC06 has OP while the HK07 is SMO. In theory the EC06's beam should be cleaner, but we'll see.
Interested
BTS: My first concept submission back in Sep 2020.![]()
These EC04 (?) each has a SS bezel.
The EC06 in this GB doesn’t and thus it looks rather uninspiring.
Initial plan was a quad xhp50.2 medium range thrower configuration with big head, but it was later replaced with 6 emitter config with a brand new body developed by manufacturer themselves.
Interested
So which batteries? I’m guessing it’s a 40 amp draw on turbo. Molicel 21700 M50A 5000mAh 15A or go lower capacity higher amps?
Interested.
Not want cuz 6500k
As I already have the Molicel P42A I’ll be using these.
Manufacturer might release other LED option(s) later. Do follow this thread closely.
Ordered. Thank you freeme.
Freeme, I like your chunkier head design. :+1:
Ordered. Thank you freeme ![]()
I guess my effort is not totally wasted after all. ![]()
We were so close to finalization back then...
