Hey guys, I bought the blue FT02s with XHP50.2. Best thing about it is the duration in Turbo with a Samsung 40T (>80 sec.). Worst thing by far is the beam artifacts. How does the SST version compare? Is it worth it?
here are some beam shots for the ft02s xhp50.2 5700k. (sorry their not great, did them quick). The telephone pole (with breaker on it) is about 70 yards out.
mf01 mini sst20 5000k (for comparison)
It is surprising how good the xhp50 FT02s is. I love my mf01 mini, and the ft02s surpasses it easily.
And here are some comparison sizes, the size of the ft02s surprised me on how compact it is (ft02s xhp50 5700k, mf01 mini sst20 5000k, astrolux C8 Osram CULPM1)
I really like this flashlight! It’s one of the better all around flashlights I own now. Over 12k lumens at start and holds 8000 lumens over 3 minutes. For under $50 it’s a crazy bargain.
Aggalitsas ^worse With sst40! I actually think the xhp50 beam is nice, for a 4x emitter setup! The ec03 and this ft02s reflectors lend themselves well to the larger die of the xhp50. My ft02s has a hot spot that’s looks like a single emitter light. It’s awesome.
Thanks for the review, I’ve been waiting for this. Despite the beam defects which I can see outdoors as well as on a white wall if I look for them, (I know, don’t look for them!) I’m happy with this light. The positives very much outweigh the negatives for me. Funny thing though is comparative beamshots from this review and also Flashaholic’s video review really make me want the Astrolux EC03! I’m still waiting for green EC03 XHP50.2 5700K to be restocked.
I haven’t seen the EC03 XHP50.2 variant to be sold with the green body color yet (only the EC03 SST40 comes in black/green/sand ; so far all EC03 XHP50.2 come in black ; however, I’m not sure whether they now have the XHP50.2 5700k or 6500k on the EC03…)
Based on my beamshot comparison, the “petal” pattern (outside the hotspot) on the FT02S (SST40) looks a bit more pronounced than on the EC03 (SST40), probably because the FT02S has a more focused (the spacing between the LED on the reflector are closer, which sort of obstructs some light from the LEDs, and creating the “petal” shadow pattern…
Mine finally arrived and quick assessment the artifact in the beam isn’t even bad unless you are less than 4 feet from a wall… anything more than 10 feet the artifacts(pedal) pattern is not even noticeable. For a light with multi LED’s using a reflector the pedals are normal… appears in my Q8, SP36, EC03 hell even my MS18 probably has some kind of artifacts in the beam…. if I wasn’t completely blinded by it
So far impressions love the ergonomics, surprised its only slightly larger than my EC03 I enjoy the fact I can run some higher capacity 26650 Shockli’s for longer runtimes.
The petals aren’t what bothered me with my EC03 sst40, it was the variations and I gues “rings” in the area outside the hotspot (corona?) and the spill. I saw rings of black (very little light) and then bright light. Maybe I’m remembering it wrong, but I just never felt good about how the beam evenness looked. The petal effect never bothers me, I have it on my haekelite hk04 and others and it is fine. It’s just uneven light inside beams kindve eeks me. I feel like i saw that unevenness in some posted pics of the ft02s sst40 beamshots… maybe I’m wrong?
To be honest, I like the EC03 beam a lot and the ft02s beam isn’t bad for what it is a d the emitters used. The EC03 beam doesn’t have much in the way of artifacts, and the cloverleaf effect of the multi reflector setup is a given. I don’t have a sst40 ft02s, but the hotspots of my old SRK and the ft02s are about the same at 2 meters, and the EC03 is smaller and more focused (due to the sst40s) and no tint shift. However, the throw is about the same for the xhp50.2 and sst40 lights. Pretty impressive on both. The 7 year old SRK I have also holds it’s own, but the XMLs hold it back. Will soon have some sst40’s though.
Yes you’re right. When the EC03 caught my attention the black color XHP50.2 6500k was available and I assumed the green color was out of stock. I know now it was never offered. I’m kicking myself now for not getting the black one when it was available.
The petal effect is expected and I see that to some extent on all of my multi emitter lights. My FT02S beam when viewed on a white wall or ceiling at 1.5 m away is kind of a mess with the darker then usual band/ring of tint shift outside the hotspot and the unevenness outside that. The band shows outdoors, the unevenness not so much. Yes, I believe the proximity of the LEDs is the cause, maybe not the proximity itself but losing the inside walls of the individual cups due to the closeness of the LEDs. A member here mentioned it was probably a design decision to increase throw but it seems the depth and size of the cups have more effect on throw then the proximity of the LEDs. It is interesting to compare the FT02s to the Haikelite HK04 with it’s more widely spaced quad XHP50.2 emitters and similar output.
Anyway, I took the FT02S on a walk a few days ago and it’s fun to use.
