Interested freeme. Thanks
See first post link.
Long press for off. Fail.
Yeah, I take back my earlier comment. Leds can be swapped but this ui and heavy thermal step-down are big issues. A shame, as lumintop finally got 900lm sustained in the fw3x not long ago.
Which light is that?
I thought the FW3A could only do around 300 lumen sustained.
It can do a lot more than that--I'm thinking at least 900 lumens sustained.
900 sustained in an ice bath maybe. Take from the review below “Without any cooling or heatsinking (air, hand) the maximum sustained output is below 300 lumens if you want to keep the surface temperature below 50°C.”
That has not been my experience with the FW3A.
The FW3A can easily sustain 900 lumens without any cooling.
300lm is rather low even for warm climate countries.
Is that just your impression or have you tested it in an integrating sphere?
My recollection from reading reviews of people who did test their lights for runtime and output was that the FW3A sustains around 300 lumens (and that’s the cool white XPL HI version) and the Emisar D4 (also XPL HI version) only sustains around 500 lumens.
Sustaining high output is actually quite difficult for small single cell lights. Even a Zebralight SC700, which uses a 21700 cell and is much larger than an FW3A with vastly superior heatsinking and an XHP 70.2 led barely manages to sustain 1000 lumens.
I own several FW3As and I think the estimate of around 300 lumens sustained is about right. These are tiny pocket rockets with no real heatsinking. It’s not surprising they dim fast. My Zebralight SC64w and SC64w HI stabilize at a much higher output than an FW3A… not suprising considering how good Zebralight’s heatsinking is (unibody construction with lots of heat sink fins).
I do not have an integrating sphere, but I know what approximately 900 lumens looks like.
That’s what I thought too until I took a closer look and read some reviews.
Try this:
- Get a light that you know turns on at 900 lumens on turbo on a fresh cell.
- Get your FW3A, turn it on and tailstand it. Let it run until the output stabilizes after temperature rampdown.
- Do the “integrating bathroom test”: Go into a bathroom with the FW3A (still on) in one hand and the 900 lumen light in the other. Do not turn off the FW3A since you want it to maintain its temperature stabilized output.
- Hold the 900 lumen light above your head and point it at the ceiling, while the FW3A (which is still on) is pressed against your shirt so its output is not visible.
- While looking at the floor near your feet, turn the 900 lumen light on max for a few second then turn it off.
- Then immediately raise the FW3A above your head and point it at the ceiling, again while looking at the floor.
- The goal of the test is to look at which light makes the floor look brighter. Since neither hotspot is in your field of view, all you can see is the diffuse reflected light. This is a bit like an integrating sphere in that it helps you compare overall lumens while compensating for differences in the hotspot.
- If the FW3A really stabilizes at 900 lumens, the floor should look the same brightness with both lights. Showing they are within approximately 20% output of each other (differences in output less than 20% are generally not noticeable to the naked eye).
- However, I think you’ll be surprised to discover that in this test the 900 lumen light makes the floor look considerably brighter than the FW3A, proving that the FW3A stabilized well below 900 lumens.
Received my FW4X adjustable tint light today.
Here are my first impressions:
- Build quality is about the same as an FW3A. Looks fine. Beam pattern is floody but looks good. Optic is frosted, but a standard clear Carclo from an Emisar D4 fits fine and gives better throw.
The UI is absolutely horrible.
- The most commonly used functions in a light are Min, Max, On and Off. A well designed UI should have all of these accessible with a shortcut. These are the basics. It is critical to have a good UI for the basics.
- On and Off should always be accessible with a single-click.
- A good way to handle Min and Max is long-press from off for Min, double-click at any time for Max.
- This is how Olight does their UI. It’s also how Anduril works.
- One other feature people especially like is infinitely ramping output. Again present in Anduril.
In making the FW4X’s UI, Lumintop prioritized ramping tint at the expense of the basics.
- Double-click from off activates the ramping tint configuration mode. Tint can be changed via a stepped or ramping UI. Double-click exits this mode.
And here is where Lumintop screwed up the UI:
- There is no infinitely variable output. Stepped only. A single-click from off turns the light on. Single-clicking from on goes to the next step up in output.
- Double-click from on activates turbo. This is ok, but it would be better to have a shortcut to this from off.
- Click-and-hold from on for 1 second to turn off. This is a gigantic blunder. If there’s one thing I’ve learned from all my years on BLF it’s that click-and-hold for ON or OFF sucks.
- There is no moonlight mode… low only. Long press from off is the only way to access low mode. This is ok, but it really should have been moonlight.
- Like Anduril, it takes 4 clicks to lock/unlock the light. However, unlike Anduril, holding the button down during lockout activates medium mode rather than moonlight. While this won’t burn a hole through your pocket I could easily see someone pulling the light out of their pocket only to find the battery dead due to accidental pocket activation. Dumb!
- Even the spacing between modes sucks. There are several medium output modes but all are sorta similar in output. Cycling through them doesn’t give a large difference in output.
- Even worse, because this UI is so different from other lights its very easy to accidentally double-click from off expecting turbo and instead find yourself in the tint-ramping UI.
I don’t see why Lumintop created this awful UI when they could have just used Anduril 2. My understanding is that Anduril 2 already supports tint-ramping and in a much more intuitive way: All the features work normal for Anduril 2, but you can 3H to enter tint ramping.
Even Sofirn’s IF25 has a better UI than this Lumintop. I’m pretty disappointed in how Lumintop executed this.
I wonder if it is possible to flash the FW4X to Anduril 2 and if so, would the tint ramping function properly.
would like to notice that there is NO acces to turbo from OFF.
