Sent.
Interested for all ,thks
Just placed an order for the SD2.
Just placed an order for SD3. The procedure for using coupons/codes has changed. See this post for details.
Thanks again for finding this offer, FreeGB.
Thanks. SD1and SD2 ordered.
Codes for SD1 SD2 and SD3 please
Thank you FreeMe, SD1 ordered.
Thank you FreeMe, SD2 ordered.
What driver is inside, FET?
Code for SD3 please.
PS. Ordered. Thanks!
Thanks again FreeMe, ordered another SD1 These will make great gifts for the flashlight impaired.
Everyone’s placing orders. Must be time to jawbone about batteries! What are people planning on using? I see the flashlight has LVP, so unprotected is ok.
Flat vs Button?
Brand & Capacity?
Vendor?
I have a SD1 with me right now. Both unprotected flat and button top works fine. 70mm long protected NCR18650B doesn't seem to fit after I have performed wire bypass on both springs.
Sanyo NCR18650GA 3500mAh 10A is sufficient for SD1 and SD2, which max out at ~3A. $13.75 for a pair.
Quite sure it is regulated but i will run a test to confirm.
all the colors r cool. if i were to buy colors, sand/fde then greens and orange.
Thanks Freeme! I’ve deleted my last post by mistake.
Is this for BLF lantern reply? [quote=liquidrazer] all the colors r cool. if i were to buy colors, sand/fde then greens and orange. [/quote]
IMREN 5000mah 15A
Hi freeme, code for SD1 please. TIA.
Any idea what the driver diameter is, if is there a driver retaining ring and what the glue situation is like?
Banggood shows the SD3 as in stock.
