Ach…
Thought my blender-grinder busted. Loaded up, keep pressing the button, and nuttin’. Unplug, replug (socket?). Uncap, recap (interlock?). Still nuttin’. Balls.
Kfine, so I get my manual burr-grinder, wash out the cup, rinse the innards with water, shake it angrily to try to dry it out asap.
Load with the beans I already poured, end up with a not-insignificant fraction of the beans on the countertop and floor. Still overflows the grinder. Double-ach.
Start cranking away, feed the floaters still atop the handle-part as room allows. Got my daily workout grinding away the assload of beans I apparently use. Thinking of just using my drill to get it done more quickly next time. Urg.
Ground ’em all, yay. Made the coffee. The grind looks pretty consistent, not powder, but still ended up with that “gremo” floating on top, and silty coffee. Oh, well.
Looked at my spinny-grinder… ok, lookit that. I saw a hairline crack on the cap a long time ago, right near the hollow in the already-thin wall that presses in the interlock tab. The crack apparently spread, and weakened that area so it now sticks out a bit, and doesn’t press in the tab. Uncap, spin 180°, recap, and it works fine. :person_facepalming:
Wellp, either gotta reinforce that area near the split, bypass the damned interlock, or just make sure that I index it the “right” way from now on when putting on the cap.
Soooooooo… the manual grinder works fine, the grind looks consistent, but is still silty.
I’d rather not go too coarse, because I don’t want to waste any caffeiny goodness, and I don’t want to have to wait too long so that the coffee cools down too much.
