Dale, thank you for the advice. The polishing paste is a good idea Thatâs especially good for tailcap or bezel threads, where it doesnât matter if they have a little bit of a tight fit.
Yeah, I calculated one messed up part in. So if I would have messed up the head completely then there would have been just enough left to do the head again. But here it was fine luckily, I just lost 10 millimetres of titanium.
Haha, I know the struggle with the Carbid inserts. They are crazily expensive but also have kind of an eternal life if you just use them for aluminium, brass and copper. A few years back I scored a deal on a sort of German craigslist and paid around 120 Euros for like 50 Carbid inserts. That should do for a long time :+1:
Thanks RBD, thatâs the word I was looking for. Itâs just hard to find all of those terms, also the translator obviously fails when I try to type in âmitlaufende Körnerspitzeâ :person_facepalming:
Well, I donât know if failing is a good thing yet I have never made such a construction with putting a wire through the body so I just hope itâll work.
You are totally right regarding the skill of machining. It takes some time to learn and as long as you are carefull (keep track of all your fingers, donât use cloth with your fingers on the lathe and so onâŠ) you are well of with âlearning by doingâ - thatâs how I learned as well. But I agree with RBD, looking at your amazing DB-02/ 04 light you seems to be doing very fine :+1:
I am looking very much forwards to your build as well Dale.
Also, I donât know how you cut the threads into your slide, for stuff like that, I always use the thread-cutters which consist of three pieces. Basically one for starting, one to get it to the right size and the last cutter finished the thread. And again, add rapeseed oil or something for lubrication.
Time to finish the head. :+1: Just the thread for the bezel was missing and space for the reflector needed to be created.
So I just turned the material down to the right diameter and created the space for the thread:
Unfortunately, my indexable threading tool did not fit:
So I adjusted and old HSS tool:
It fitted:
After adjusting the belts for a thread with 0.75 millimetres thread pitch:
I sharpened the HSS steel and started on the threads:
After having been done with the threads it was time to part off the head:
Usually, if there isnât a hole in the middle I donât part the workpiece completely off but saw the rest:
Next the head had to go back on the lathe so I could create the space for the reflector. First I checked if the head was sufficiently centred in the chuck:
0.03 millimetres are within tolerance but not more. Since I didnât have time to grind out my chuck yet (so many things I want to doâŠ) it sometimes takes some time to get the part centred.
Again, just drilled a hole:
and widened it with the boring tool:
After adding chamfers and taking off some of the threads off I was done with the head:
So, nearly done, just the bezel missing :
Thatâs it for today, thanks for reading and following me so far Enough with flashlights for now, I have to repair something else:
Can anyone guess what thatâs for?
Thanks! Just like the water flushes in a different direction, flashlight heads are made the other way round here
So slowly I also have to start working on the driver. It will probably feature 7 AMC7135 380mA ICs, together with an Attiny 45V or 85V. But I could use some help there, since I havenât done that before. I also kind of already designed a board for the switch and just hope itâll work. I will see. Maybe I will open a new topic in the modding area to ask for help there.
At least I got my sewing machine pedal repaired
I ordered another poti and a more sturdy gear:
The parts needed:
And assembled and working
So, enough boring stuff - later I will continue with the bezel!
Time for the last part, the bezel. First I wrapped the up the rest of the light in tape so it didnât get any scratches:
Next I got what was left of the titanium down to the right diameter for the bezel:
The outside of the bezel was basically done I continued like usual with the inside:
Everything was ready for threading:
Remember to take good care of your tools and add oil/ grease from time to time:
The finished thread:
I test fitted the thread to see if it worked:
After adding some chamfers the bezel was ready to be parted off:
If you put a small brass rod or something into your drill chuck you prevent the part from falling down and scratching:
The parted off bezel:
And I finished the day with some delicious dinner :
It was a nice butterfly But I have to be grateful towards my girlfriend since she made that. Right now, my girlfriend and I are in Germany at my parents place for a few days since we were travelling around in Germany anyway (seeing some mountains since Denmark is as flat as a pancake, haha). However, we made a deal that sheâd make dinner while I do flashlight-stuff, if I make her a flashlight as well So I am actually making two flashlights right now.
I came to like the ULCp lenses from flashlight lens. These transmit 97% of the light and are more sturdy than glass lenses. The downside is that they scratch a little easier, but I havenât had to exchange one yet, also I rather have a scratched lens than a broken one. Another advantage of these plastic lenses is that you can just turn them down to the desired diameter on the lathe, so I donât need to think about whether there is somewhere a lens out there which has the diameter I need but just make my own lens.
Really amazing to watch all the steps to make a light. Mind boggling for some of us.
I am very glad that I let my lathe go. I know a lot of people would never understand, but once I tried to use it, I saw that there was no way I would ever be able to comprehend any of what you guys do. I never got past basic 2+2=4 math and I just could not even cut a piece of stock, to any controlled size, let alone cut a thread. It took me getting one and almost ruining it, before I could understand that and I am so sorry about that, sorry for everyone here, but now, with things the way they are, it would have had to go anyhow and the result would be the same. Sorry for being off track here. I felt I had to mention it.
So good to see you machinists here, making stuff most of us can never hope to do. It is inspiring to watch all of the builds here. I do have to say, I would die for, (sorry, pun not intended), some of those meals. Your girlfriend is a great cook!
Thank you OL for the nice words towards all of us! Not everyone can do anything and thatâs no problem. Man, if I tried the same stuff as people do in the handmade category Iâd either break my tools or my fingers :person_facepalming:
What I want to add is that while it is not easy to make a flashlight or to use a lathe and not everyone can do it I also hope people get inspired by this contest, to try out new things and see that it is not magic but a long and steady process to make a light. You donât just start with a chunk of metal and suddenly end up with a light, there are many small steps one has to go until a light or anything else for this matter is done. While it takes time and patience to learn how to use a lathe or any other skill I also want to encourage and show what is possible.
Thanks, she is an amazing cook and I think I made a pretty good deal by trading a light for her making dinner
I resized the pictures to 1200 x 900, I hope the page will load a little faster now.
I got some more stuff done and finished the bezel.
Here the parted off bezel:
Like every other part I left a few tenth of a millimetre extra, so I had to measure how long it was and take away the excess material:
Before changing something I measured the roundness on the lathe:
After that I turned the bezel down to the right length:
And added some chamfers:
I wanted to have some indents so I could see if the light is on when I put it down with the head facing downwards. Also I like how it looks:
And the bezel is done:
Thatâs it for today. I will work a little on the body either later today or tomorrow since the groove for the wire isnât big enough. Anyway, thanks for reading.
Youâre right, many small steps added together to make something and always different for each of us. Thats what makes it so entertaining, not knowing what someone elseâs next thing will be. how they will do it, or how it will look. It grows before our eyes piece by piece. Thanks for resizing, it loaded so quickly I did a double take to see if I was in the right thread. :+1:
Like I mentioned the groove on the body was not deep enough for the cable. When I tried to insert a battery into the tube it got stuck, so I had to make it a little bit deeper. What happened was that the tool I made got pressed away after a few millimetres into the material (I suspect that my lathe wasnât sturdy enough there). Well, after wondering how to best to it I decided to use my milling machine/ drill press to deepen the groove. First put the head together with the body into my rotary table. I also measured the deviation in the x and y direction:
To my surprise it was less then 0.01 millimetres right from the start (my rotary table isnât very good. That was kind of a bad deal I made there), which was fine:
Next I noticed that I didnât turn the grooving/ threading tool down to a specific diameter, since it didnât fit in any of my collets. So I turned the diameter down to 16 millimetres:
Now it fitted in the collet:
I used the fence, so I didnât hammer into the head and in the worst case break the blade:
Turns out that it worked very nicely:
I should have done it that way right from the start that would have saved me some time. But well, as long as it turned out fine.
Thatâs it for today, thanks for reading. Soon I will be done with the mechanical stuff, then I have to go on with the driver, the switch and the firmware
If it ainât broke donât fix it but when it is you get to make it better. Is it possible to reface either the jaws of the rotary chuck or the bottom face it rotates on? Sounds like either the jaw faces arenât square to the grooves or the whole thing is precessing. I donât know tools like this but I visualize pretty well and enjoy guessing.
This is a real textbook on flashlight machining. Readable, entertaining, and best of all, educational. Thanks for taking the time to explain everything!
That probably would be correct if I had bought a proper rotary table. Unfortunately I bought one of those: http://www.ebay.co.uk/itm/RDGTOOLSâŠ
I donât know yet what to do with it. Either I will sell it and buy a proper one or just buy a proper one additionally and modify the one I have so it is kind of usable. But right now it is really annoying using it, you have do a lot of measuring and in the end the precision isnât very good anyway.
But luckily I am done with using it for this light so thatâs a problem for another day
You also see that good tilting rotary tables have the axis in the middle or close to the middle. The one above has the axis in the front so it completely lacks stability.
