FS : LED centering rings / positioning / insulating – made to your specs (CLOSED)
Hoop, have you looked at the recent comments starting around
and on up around and past this one (if these links work)
about the CPFItalia zoom light maybe needing a washer, maybe a “shoulder washer” to keep cells from shorting out to the brass pill instead of staying centered on the spring?
Might be your approach would be able to make the needed part, if we can figure out the size/spec
