Test cut a couple of the S2+ xp series rings. It seems the process is more forgiving than I thought it would be so I will probably be able to make these out of black acetal (delrin) rather than nylon. :bigsmile: Acetal machines a lot nicer than nylon and should require less deburring effort. I will test the process with acetal shortly.
I usually sand down the centering ring bottom side and then use superglue to prevent it from rotating when tightening reflector/bezel. I also put a tiny-tiny bit of grease on the top edge/lip of centering ring where reflector will sit so that it could slide more easily when I tighten everything up
Hi fellas. I got into a rather large machining job which I had to prioritize and haven’t had time for anything else. I see the light at the end of the tunnel though and will be able to get back to my fun/hobby projects soon. I will update when I cut some of these these from black acetal.
shrick, I’d recommend using acetal (delrin) if you make them manually. It’s doable but not the easiest project for a novice and it will probably take more effort than it’s worth. As for the tiny end mills, you can use a 1/32” 2fl which shouldn’t give you any trouble in acetal. In the square pocket, machine a relief past the corners in one axis to provide clearance, at least the radius of the cutter in length.
I just notice this thread, but Hoop doesn’t seem to online very often. I would like to order a few pieces of XP-G2 size to new Convoy C8 XM-L2 reflector, is this offer still going on?
would such an XP2XM-Adapter be possible? Outer diameter of XM-Footprint and inner Diameter of the XP-Footprint so they could fit the original centering adapters. I often swap XM-L2 against XP-L or XP-G2. At the moment i make these by hand with a file from an XP-centering adapter …
I would buy like 20-30 of those if I could get some. It frustrates me to no end that I can’t get an XM centering ring just with an XP internal dimension. It seems soo simple and yet no one has them and the fasttech ones suck, have already tried them.
