Yeah, but CELNM1.TG has a tiny thermal pad. And it doesn’t make up for this with smaller thermal resistance inside the package - actually it’s a bit worse here too. So likely it won’t be possible to overdrive it so much.
There is also this larger version, closer to the Q8WP koef3 tested recently that got almost as high cd/mm^2 as the black flat.
LE UW Q8WP: White 4.20 W 533 lm 153 cd 1650 mW 473 mW/sr 130°
(die size 1.91mm^2)
KW CSLPM1.TG: White 4.20 W 515 lm 171 cd 1590 mW 529 mW/sr 120°
(die size: 1.99mm^2)The main difference is that the KW has no side emission like the Q8WP did so possibly more of that light is going forward and could potentially give higher cd/mm^2 despite larger area and lower stock output.
This also has a much smaller thermal pad than the older LED.
Due to better efficiency I find it interesting, but I don’t expect it to beat Q8WP.
It’s interesting that now we’re discovering several years old emitters that are great for our application.
And sad how the later generations are often just inferior for what we do.
And what’s worse - we’re not a big enough market to even keep an old product alive, let have one developed for us.
