Here is another thought.
Fritz designed this light , let him decide the finish & the rest of us can just deal with it if it happens to not be our particular preference. :+1:
I liked the original intention to try and show the work put into it, and it seems as if the best way to reflect that intention is to leave it mostly bare or maybe polished from bare. In another light, the anodization lets you do mechanical lockout by breaking the connection. Here, would this do the same thing regardless of anodization by keeping the inner tube from reaching far enough? If so, I think that would make a good case for leaving it bare or maybe seeing if they can polish it. Of course most but presumably not all of us may be willing to polish it ourselves, so long as it was just to make it shinier and not because of stains. I think itās too easy to make the clear anodization look cheap, and not all of the prototype versions looked that good, but it might be alright. The seams were different version of the clear process, not accidents, right? I have the gray d4; itās not bad but itās not the look this was originally going for. I think bare makes sense.
In the FW3A, current travels through the outer tube, the threads, and the driver retaining ring. Loosening the body from the head does not break the flow of power. However, it does break the connection to the switch, so it canāt be turned on/off when loose.
None of that depends on being anodized. The anodizing is a purely aesthetic feature on the FW3A, and not relevant for physical lockout. Plus, the soft lockout is quicker, only takes one hand, and is probably more effective.
Both prototypes had it, but itās a lot more noticeable on proto2.
However, Iāve heard that it took Convoy a while to get the clear anodizing right, and even then, it seems to be so thin that it can still conduct electricity sometimes. On my clear C8, I can measure electrical contact between a bunch of different places on the outer surface of the light.
So you can lock both on and off; which seems fine. Yeah, I thought the anodizing didnāt matter, thanks for confirming. Means thatās not a disadvantage of bare.
Just an FYI: the above only applies to lights that donāt have a PC board that the spring is soldered to. The PCB is isolated from the tail cap and completes the circuit between the negative terminal and the main body by making contact with the unanodized end of the battery tube.
Good example. You can see that the PC board isolates the circuit from the tailcap and you could sand off the anodizing and still have lockout.
Hereās a link to a pic from TKās review. http://toykeeper.net/torches/emisar-d4/full/tailcap-inside.jpg
That ring of copper is what the body touches when you screw it on.
But back to the FW3A, I canāt imagine any of us are too worried about the finish as this will be a āuserā rather than a shelf queen. :laughing:
Hmm, yeah it does. I do remember hearing that it was not so with another; maybe thereās some difference in the way the titanium one works, and thatās what I was hearing about. But yeah, I donāt think for a moment this wonāt see some wearā¦ might look better to not anodize and just polish scratches out as best as possible; regular anodizing isnāt immune anyway. I could go either way.
The tailcap might be able to do lockout by loosening it, but I wouldnāt recommend it. Itās not really meant to be unscrewed. It makes the clip loose, allows the tubes to slide relative to each other, and could still make contact by pushing the button hard enough to pop the rear PCB loose.
Soā¦ keep the tail end tightened up unless youāre swapping the button or clip or something. Change the battery at the front end instead.
And as pinkpanda3310 stated, this will also eliminate stretching out this project even further.
That in itself is a win all the way aroundā¦ā¦ :+1:
ā¦
Honestly, the finish doesnāt matter to me at all. Not a bit, especially if it wonāt matter with regard to a physical lock out. (Iād prefer a physical lock out, given the option, by the way). So, I agree, let the designer decide.
