So, did Lumintop tell you when the light will be revealed/be able to buy?
I’ll be buying one the second it goes online.
Also, could you check with a magnet if they are steel springs or not?
They look exactly like the BeCu spring from the GT Mini.
What a lovely looking little light. Can’t wait to get mine.
When I put my name down for one, I didn’t choose the emitter. Do I need to say what I want now, or do I get given the choice once the group buy activates?
Wow…. very nice!!
Thank you for the detailed report & great pictures maukka. .
Very nice! Noob question: what does the “1” in “1+6+FET” represent?
1x7135+6x7135+FET driver.
It’s a triple channel driver.
You can get very low moonlights with 1x7135 mode.
You can get an efficient 1000 lumen with 6x7135.
You can get max power with direct drive over the FET with 3000+ lumens of output.
Ah gotcha, thanks!
I am on the list for 1. Can you update that to 3 with the LH351D.
TK corrected me and said it’s actually 1+7+FET. Two chips on the other side.
2 Questions for anyone able and willing:
In reading on Anduril on the OP page…it appears infinite variable brightness….but just wanted to make sure I wasn’t misunderstanding.
2. The optics. It appears there are several easy swapouts (some mentioned to be sold by MTN on a previous page here). Is it as easy as screwing off the bezel and swapping? Or is there glue or other tools involved?
TIA!
1. All of that is configurable. It’s just that the default stepped ramp mode goes up to the 800 lumens and to turbo from there with a double click.
2. Easy to swap MCPCB and LEDs or optics (Carclo), no glue.
Maukka, thanks for the analysis, and the good hard work you have contributed to this project!
I plan to purchase this version of the FW3A, but would like increase the throw. I get about 12000 cd from my current EDC Thorfire TG06S and would like to at least duplicate it with my new FW3A.
Approximately how much throw would be gained by going to a clear lens? Are there any other easy mods that would further increase the throw? Thanks!
Shouldn’t turbo be closer to 3000lm though?
The lowest mode is approximately how low?
I hope the muggle mode goes up to the 7*7135 level.
Is the build quality of the D4 better?
I’m down for one.
Please count me in for one of each:
I haven’t tested different optics with the XP-L HI yet, but will post numbers later with the 10507. You’ll probably gain about 20-40% more candela.
With the narrow clear optic and the xpl-hi you should be able to hit 12,000 lux. Using SkyLumen specs his lights achieve 15,000 lux.
I prefer an “A” or “D” as far as the black body Locus is concerned. Below or ideally, at, the line. But we seldom get our choice in these matters.
So I agree with Tom in the choice of a D, not in the choice of a 5. 2A or 3A would be my preference most of the time. I prefer white, no tint. No green or blue or purple or pink or orange or rose or brown, just white.
My Avatar is in color, by the way. 17 emitters, in moon mode. White. Or very close to it.
Same here, A and D. Didn’t realize that was a color pic. Very nice!
Please add me for another
