Speaking about the UI and Narsil, i only recently experienced it with the Emisar D4 and have a few issues with it. I understand the D4 uses a stripped down version with ramping only and no other mode groups to chose from.
Im nearly 100% positive that the regular Narsil M does just what you say. From off press and hold-ramp to some med output(leave on at least 1/2 sec)-click off(output memorized). Long press- to moon -click off. Quick click- back to the med output memorized mode. Double click from any mode except turbo- Turbo- click off. Quick click on-back to memorized mode.
After you've set the memorized mode, if you press and hold from off to get moonlight, you have to be sure to let go while at the lowest output, so pretty much you have to let go as soon as you see light or it will reset the memorized mode. This is with NarsilM.
If I recall correctly, Tom already implemented those memory suggestions. However, Iâm not aware of any features to limit maximum output.
Iâve been pondering how to configure the lowest level; maybe I could also make something to configure the highest level. Iâm doing a somewhat different interface though⌠instead of pre-defined mode groups, the user sets the number of modes and the brightness of the lowest mode. Perhaps they could also set the brightness of the highest mode. Afterward, the discrete ramping then has the selected number of evenly-spaced steps between the endpoints.
The upside here is that itâs simple, flexible, and always evenly-spaced. However, the downside is that it would be unlikely that any discrete levels would hit either of the sweet spots with a 7135 channel maxed out.
Iâm also hoping to make it relatively easy to switch between smooth and discrete ramping, without a trip through config mode.
Just some thoughts for now. Itâll be more concrete later.
Ahh, I wrote both versions, but TK took over the D4. Not sure why a 100% of the 7135 is a nice feature for power up default - never thought of it, but it's easy to do in NarsilM, in fact I think I have something similar as a compile switch option, but it might go to max or something - think Lexel requested it. I "think" NarsilM is still more advanced, but not familiar with TK's mods.
NarsilM v1.1 will be made public soon, and it also has some new features, mostly intended for the GT buck driver, but two main feature additions:
has a momentary/tactical mode, accessible by 5 quick clicks (sorry, 2-4 were already taken)
the ramping can max out below the max/turbo level, so you can make ramping's max 80% for example, but the double-click to turbo will still be 100%.
For ramping, I think the 150 levels at 16 msecs each takes a bit long. Been experimenting with 120 or 135 entries.
150 = 2.4 secs
135 = 2.16 secs
120 = 1.92 secs
It actually takes a little longer, because there's a pause at moon level.
Also, not sure if many are aware of it, but NarsilM v1.0 will be in the launched Q8, and it also has a "Restore Factory Defaults" command.
For the FW3A, I assume it will be at least NarsilM v1.1, but if the D4 firmware is preferred, no problem there. Might be a merge up and coming, or new versions TK is working on. We still have inherent limitations in the ATTiny85 MCU, so would still like to pursue using an ATMEL with more memory (16 KB) and more I/O pins, that also comes in a smaller package - lot of advantages...
It's all a matter of time mostly - when the D4 is productionized, who's got time for the further development, etc.
I have a completely unrelated question. I was thinking of using a drilled optic that holds tritium vials. Is that a bad idea based on the heat this light will likely generate? Perhaps if I limit the max level?
Just seems like one of many usage scenarios. I've used lights in walking trails and I like the idea of setting a perfect level of brightness, but most of the time, walking with the light OFF. But I can simply get back to the level I previously set, which is ideal for this scenario. 150 lumens may be useful, may not be, for this usage. I'd rather be the one setting the level, not the light forcing me to a specific level. I do like the idea of getting to the max 7135 level though, since it's an efficient setting.
