Neal stops shipping in Russia a few years ago, and with drop shipping price of the glass will be incredibly high
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
so a 14500 variant is releasing soonâŠ
Saw that, hopefully they make it a single emitter not triple.
looks to be triple.
Sorry. Where is this info?
Thanks. Does not look like a good use of the 14500 form factor.
Can anyone tell me where I can get spare ar coated lens?
So if someone wants to know - I have contacted Lumintop via AliExpress and they send me this glass for 6$
I bought my FW3A in November 2019 with SST20s and I EDCed it for a while but, believe or not, I put it away. I read something in a post that rekindled my interest and even ran a few tests. I was messing around with it in my 'box', after calibrating it, measured turbo, repeat turbo and max ramp. It looked like this and I'm wondering what causes the pattern circled in red... specifically the half-way point of the peak.
Thank you!
Iâm wondering what causes the pattern circled in red⊠specifically the half-way point of the peak.
Thermal regulation.
Updated the top post:
Warning to potential buyers (2021)
The FW3A design has been changed many times since launch, with quite a few downgrades. It is not the same light any more. The 2021 model appears to be downgraded so much that it is no longer compatible with the upstream FW3A firmware. Itâs missing an entire power channel, as shown in the pic below.
Additionally, the FW1A has been downgraded in at least two major ways â the reflector no longer focuses correctly, and the driver no longer has the primary regulated power channel.
These are only a few of the many downgrades though. Almost every time a new batch was produced, people reported surprising new changes, and most were not for the better. Several vendors have dropped the entire product line because it had too many problems and they had to issue too many refunds.
So, be warned: If you buy a FW3A, FW1A, or any of its other derivatives, you probably wonât get the light described in this thread.
Left: Original FW3A driver. Right: Downgraded version from 2020-12.
Total coincidence, but I just noticed this update was comment #13666, a combination of two of the most famous âunluckyâ numbers â 13 and 666.
A great flashlight has apparently been ruined. A great flashlight that was not created by the manufacturer, who should have felt very fortunate. I find it disgusting.
Wow, I wonder what the newer driver design is. FET+1? Different MCU? Different firmware?
This is truly sad. Youâd think that makers such as Lumintop would actually improve something created by a small project initiative. They took something great, watered it down, and then made it unreliable. I was wondering why weâd be seeing complaints from people when early release lights would behave just fine. Now⊠we know.
I had a feeling something was up when I saw significant changes going on with the BLF LT1. Notably, in the version produced by Sofirn. The LT1 v2 showed a number of board changes. If the FW3A is now neutered to the point where upstream software wonât work properly, what of the LT1?
Is the original design public? I wonder if someone else can start manufacturing it. There are also tail switched Anduril alternatives like the Noctilux KR1, though it is bigger than the FW3A.
Oh well, Iâm looking forward to the SP10 Pro and hope it doesnât get messed up like this.
<b>Warning to potential buyers (2021)</b>
The FW3A design has been changed many times since launch, with quite a few downgrades. It is <i>not</i> the same light any more. The 2021 model appears to be downgraded so much that it is no longer compatible with the upstream FW3A firmware. It's missing an entire power channel, as shown in the pic below.
Additionally, the FW1A has been downgraded in at least two major ways -- the reflector no longer focuses correctly, and the driver no longer has the primary regulated power channel.
So, be warned: If you buy a FW3A, FW1A, or any of its other derivatives, you probably won't get the light described in this thread.
<a href="https://www.reddit.com/r/flashlight/comments/om5yja/hey_guys_i_just_received_an_fw3a_sst20_with/"><img src="https://i.redd.it/p590baszfsb71.jpg" style="max-width: 100%;" /></a>
Thanks for pointing this out.
I got an older FW1A (more than a year ago) and another FW1A a few months ago. Both are the SST20-4000k version.
They both have the driver as shown on the left side of your photo (not the "v1.1 2020").
Visually, the reflectors look the same, but I tried to compare beamshots, and noticed that the older reflector was more focused, while the new reflector has a bigger hotspot.
left side: Lumintop FW1A (SST20 4000k, older batch)
right side: Lumintop FW1A (SST20 4000k, fairly recent batch)
both of them use the same driver (as in the left side of the image posted by FW3A Team)
If I understand correctly, the new driver is a FET+1 and I think it uses the fw3a-219 firmware. At least, thatâs what Iâve heard from people who got one recently.
What that means is:
Iâm guessing the driver was changed to reduce costs again (cha bu duo), but someone noticed turbo didnât work without the third channel. Normally, channels 1 and 2 (regulated) are turned off at the turbo level, because a DD FET (channel 3) is brighter by itself. But after moving the FET to channel 2, no more turbo. So they switched to the 219 firmware instead, since it keeps channels 1 and 2 on at turbo. Perhaps they donât expect anyone to notice if thereâs no difference between the ramp ceiling (130) and turbo (150).
The original project got delayed for like a year because Lumintop couldnât meet the specified quality standards⊠but then it went to production anyway, and there were frequent quality issues. Vendors reported a really high rate of returned items, and Illumn had to manually adjust and test each light before shipping. So it didnât get carried for long.
Over time though, parts kept getting changed, usually to cheaper versions. Like, for a while, the Carclo optic and lens got replaced by a one-piece plastic imitation which was a huge downgrade. There was a lot of backlash from that though, so the lens was brought back and the optic was redesigned to be a bit closer to the original.
Another frequent issue was that the driver cavity frequently wasnât big enough for the driver, so a bunch of lights were made with the driver sitting on top of where it was meant to go, instead of inside its compartment. This made the connection flaky, and made batteries not fit right, and was one of several sources of unreliability.
The springs got downgraded at some point, using a type which had some sort of coating which flaked off easily, and got flecks of metal all over the inside of the light. This caused a bunch of electrical shorts, and more unreliability.
The button got downgraded from its original ~800g pressure to only ~300g, and sometimes even less. This made it hard not to activate by accident, and people had to carry the light in lockout mode.
The entire tail end got redesigned several times, and I donât know if it was ever fixed to be reliable. Itâs famously finicky.
A bunch of spinoffs were made, and some were embarrassingly lazy. Like, the 21700 version seemed like it was simply scaled up without adjusting proportions⊠so the battery compartment ended up so long that it didnât fit the cell it was meant to use. Because 18650 scaled up to 21mm width⊠is 21x76mm, not 21x70mm. So a common 21700 cell needed a 6mm spacer in order to make contact. The clip wasnât adjusted either, so it was too short. The optic was simply reused, instead of scaling it up for better throw⊠and it had a bunch of empty space around it. Etc.
And now half the driver hardware is missing. I guess itâs more of a âFW2Aâ now.
The problematic tube design was never corrected. Mention it and a handful of people will instantly tell you that youâre too stupid to fix it yourself.
With so many fanboys, why should Lumintop make this light better?
