The Tiara C1 Pro with 18650 is the same setup I use most too because of the much longer run time and no stepdown (or takes very long) due to the increased mass and surface area of the longer tube to reduce heat gain speed and increase heat dissipation rate. I use the 18350 sometimes when I want a super pocketable light, which I use for night time picture taking. The HI CRI light is way better than the flash on smartphone cameras and much brighter.
UPDATE 190301: Store news
- A new batch of E21A order placed to Nichia two days ago. There will be full line-ups of E21A coming. ETA, mid March
- sm203 (R9050),
- sm223 (R9050),
- sm273 (R9080),
- sm303 (R9080),
- sm353 (R9080),
- sm403 (R9080),
- sm453 (R9080),
- sm503 (R9080),
- sm573 (R9080),
- sm653 (R9080)
- Hopefully triple Carclo compatible E21A MCPCB can also keep up not long after. Still need more funds for that.
[Clemence]
Clemence, would it be feasible to factory drill optics holes in mbpcb so the lens sits lower?
Don’t worry, I actually did the test investigating the possibility of the new VR20SP3. The focus will be adjustable by shimming.
[Clemence]
Clemence, since you have not made the triple e21a, can we wishlist individual addressable LEDs on it? ![]()
Done! It’s seriiies/parallel/iindiividual addressable
[Clemence]
Good news :+1: , I will be probably in for several of them.
Can you make it Jaxman E2L compatible (I mean, leaving the possibility of sanding of the edge of MCPCB to make it only 19mm diameter)?
Also, will there be VR20S1 MCPCB as well (for both single E21A and 144AM)?
19mm is not a common size. It’s better I custom make it from VR20SP3, there should enough margin to do that.
No plan for VR20S1, after this VR20SP3, the next MCPCB will be VR38SP16,
Tip: You can convert existing VR21SP4 to single E21A use by scraping the solder mask.
[Clemence]
adam7027:
clemence:
Can you make it Jaxman E2L compatible (I mean, sanding of the edge of MCPCB to make it only 19mm diameter)?
No plan for VR20S1, after this VR20SP3, the next MCPCB will be VR38SP16,Tip: You can convert existing VR21SP4 to single E21A use by scraping the solder mask.
[Clemence]
I’ll jump-start for the VR20SP3 then ![]()
thanks Clemence.
VR38SP16 will be insane! Gonna get some of your new creations from you for sure.
Do you know, what host(s) and optics support that board? ![]()
SKV89:
So far I found Jaxman X6 (XHP70.2) is decent host for it
[Clemence]
staticx57:
[Clemence]
Awesome! Tint mixing+color is first thought but there has to be a ton more ideas this would bring.
Very nice! That is a really great range of options!
What’s the flux bin of the sm353 and sm403?
sm203 D160 R9080
sm223 D180 R9080
sm273 D200 R9080
sm303 D200 R9080
sm353 D220 R9080
sm403 D240 R9080 (old stock)
sm453 D220 R9080
sm503 D240 R9080
sm573 D240 R9080
sm653 D240 R9080
[Clemence]
adam7027:
SKV89:
[Clemence]
I hope somebody will be able to produce a ‘soda can’ build with this ![]()
(but maybe Jaxman X6 is more suitable to produce higher sustained output)
clemence:
adam7027:
SKV89:
[Clemence]
I have my eye on a specific light to be used as a host. Waiting patiently for this board to be for sale ![]()
D240
no thanks, it may look natural and be slightly brighter but it’s too green in my opinion.
But mixing 2*sm353 with 2*sm453 should result in a nice 4000K with a rosy tint.
