Anyone have the size of the coil? is it 7 x 7 x 3 mm ? ….or 4 x 4 x 2 mm…?
Looks more like 10 x 10 x 4 mm judging by the picture a few posts earlier…
But those are 1R5 = 1.5 µH.
Hmmm…
Either way, those sizes are usually rated > 10 Amperes, so it surprises me that they get hot.
I tried to set brightness level by connecting KEY and ground ()> it doesnt work,
and about max brightness, I got 1.57A from 2S samsung ICR18650-26FU laptop pulls charged to 7.95V, same results using INR18650-30Q at 8.26V. (stock R100).
I’ve read few replies here saying that the driver could be resistor modded but i could not find what value resistors were used. I am not skilled to determine that myself.
So if anyone knows what value resistors i need to make this driver output about 2A i will be happy to know that
In an Haikelite HT35 I stacked the R050 of the LD-51 with an R100 and I got 2,25A at the LED. Now I have a XHP70@12V in it, because my XHP35 has a black dot in the middle, after two R100 on the R050. That was too much.
With the two R100 I got flickering on turbo after the black dot in the LED. Now with only one R100 there is no more flickering.
Thanks a lot Wieselflinkpro, that was the answer i was looking for.
I added R120 resistor over the R050 one and got 1.97A at the LED. WOHOOOOOOOOOOOOOO!! Right on point, i just hope that the driver will survive at this power level.
So R120 is a 0.12 ohm resistor? I’m just learning the notation for these things.
Is it 1206 size needed on the LD-51?
Where do you guys get these resistors, do you just pull them all off of dead electronics? Could I buy a good assortment of SMD resistors to “jump start” a collection?
I stacked 1206 (3216) over the R050. Stock sense resistors (i believe there are two?) are bigger, not sure on exact size but they are bigger, i had no trouble stacking the smaller resistor over the stock one.
If you buy SMD resistor kits then i would suggest to go with 1206 because the bigger ones might not fit some drivers if used to replace or stack resistors.
1206 is usually good. Sense resistors are basically a normal resistor with a higher power rating. It’s just a term that singles the higher wattage resistors from the rest. Usually bigger means higher power rating in general but smaller resistors can have higher than bigger as well. Now it comes down to price as well. Small resistors with high power ratings will cost more than the equivalent rating in a bigger package. And then… there are many qualities and brands to concider.
The good part is that for what we need, we just select the appropriate value and power and cheap.
