products of category of the LED Lights & flashlight http://www.gearbest.com/led-lights-c_11264/ (link is external) ( full-price item)could get 8% off discount via the coupon of GBLED2016
● CREE XPL HI LED, delivering max 1095LM output
● 6500K and 5300 - 5400K for your choice
● 5 modes: high - low - strobe - SOS - dimming light
● Side switch and twisty tail switch, side switch of infinitely variable brightness function
● IPX-8 waterproof standard, let alone rainy days
● SMO aluminum reflector with spotlight and 523M long beam
● Body with anti-slip knurling, cooling slots of high efficiency
● Powered by 4pcs AA batteries, ensuring max 95min runtime
● Cree XPL HI 1A / 3A or XM-L2 U3 1A LED - Max 1100LM output, 5 modes: turbo 2.8A - high 1.2A - mid 0.2A - low 0.01A
● 6000 - 6500K ( 1A ) / 5200 - 5500K ( 3A )
● White light is of high brightness, neutral white light is close to daylight, ensuring the users to identify and recognize the target accurately
● Instant strobe - Double click at any mode to enter Strobe
● Memory function - Turn off the flashlight for more than 2s, turn on again for previous mode
● Low-voltage warning -When battery voltage drops down to 3V, the light flashes to inform users
● K1 made of aluminum alloy in back, K1S made of stainless steel in silver
● Comes with red, blue and green rubber caps, which act as filter and gives you more fun
● Cree XP-G2 R5 LED, max 100LM output
● 4 modes ( Mid mode default ): high - mid - low - strobe
● Constant current circuit ensures constant brightness
● Streamline pendant design, can be attached to necklace or keychain
● IPX-8 waterproof standard ( 2m ), let alone rainy days
● Reverse polarity protection prevents inappropriate battery installation
● Acrylic optical lens, max beam distance up to 45 meters
● Powered by AAA battery, enduring max 110h runtime
● The HR20 is a lightweight and multifunctional headlamp, weighting merely 46g
● Utilizing CREE XP-L HI LED in conjunction with copper MCPCB, max 1000Lm output
● Rotatable brightness adjustment to any desired brightness, coping with multiple unexpected accidents
● Built-in Micro USB charging port, the battery in the HR20 can be charged conveniently
● Innovative switch design for easy operation
● Optimized lens and reflector for impact resistance and excellent beam
● IPX-8 standard waterproof (2m) for severe weather
● Advanced temperature control module prevents over-heat
● Aerospace grade aluminum alloy construction with military hard-anodized finish
● Headlamp and flashlight dual use, necessary lighting tool for inspection equipment and outdoor reading
products of category of the LED Lights & flashlight http://www.gearbest.com/led-lights-c_11264/ (link is external) ( full-price item)could get 8% off discount via the coupon of GBLED2016)
Hi serp, if promotion is over or cost raised, then price will be rise, which products do you love, I could ask our related staff if they could promote it again
