Olight is celebrating their 10th birthday with a present for its customers - the Olight ION flashlight, one of the most unique and stylish pocket-sized lights we've ever seen! This box-shaped light features a one-of-a-kind body design never before seen in a flashlight, crafted from durable gorilla glass with a sturdy titanium frame. No bigger than a Zippo lighter, this compact torch comes with a detachable key ring for easy fastening to your keychain, making it an ideal EDC light. The ION even comes with a special inscription on its back, celebrating the company's decade of excellence and thanking its highly valued customers!
The ION is equipped with 2 top-of-the-line CREE LEDs, which combine to produce anywhere from 1 to 320 Lumens of cool white light. In addition to its easy to use ON/OFF side switch, the sophisticated keylight is operated using a pair of pressure sensor switches on its body. Simply press the plus or minus symbols on the ION's gorilla glass body to cycle between its 6 unique outputs. This one-of-a-kind advanced interface has never been seen before in a flashlight, making this device all the more impressive.
Every aspect of the Olight ION is unique, its power source included. Rather than rely on separate batteries that need constant replacing, this handy keylight comes with a built-in Lithium Polymer battery pack, which can be recharged through the light's micro USB charging port. As you use the light, you can keep track of just how much charge is left thanks to its LED power indicator, located in between the light's pressure sensor switches. While the light is on, the indicator will glow either green, yellow, or red to signal how much juice the battery pack has left, so you'll never be surprised by a dead battery!
Main Parameters:
LED: 2 x CREE XP-G3 CW LED
Power Source: 1 x built-in 300mAh 3.7V lithium polymer battery pack
Max Output: 320 lumens
Max Beam Intensity: 750cd
Max Beam Distance: 55m
Waterproof: IPX0
Brightness Levels and Runtime:
Max: 320 lumens ( 27 minutes )
Mode 1: 160 lumens ( 1 hour )
Mode 2: 40 lumens ( 4 hours )
Mode 3: 10 lumens ( 16 hours )
Mode 4: 2.5 lumens ( 45 hours )
Min: 1 lumen ( 90 hours )
Product Features:
● This flashlight has a rectangular structure, one-of-a-kind gorilla glass body with titanium frame.
● Thanks to the dual LEDs and TIR optic lens, the ION has a soft, balanced beam profile with a wide defined hotspot and wide angle spill light, that is capable of a maximum output of 320 lumens and a beam range of up to 55 metres.
● There are pressure sensors in the “+” and “-” areas which allow the user to select either preset brightness levels or a gradual custom brightness setting.
● Built-in rechargeable LiPo battery can be charged through the micro USB port located on the side of the flashlight, it only takes 1.5 hours for a full charge.
● First flashlight in the world that controls the output through built-in pressure sensors under a glass control panel in a 1mm thin frame.
● Easy to operate, single press to select from four preset brightness levels, or press and hold for a custom output, ON/OFF slide power switch located on the side for quick power control.
● Remaining battery power indicator - green (>75%), yellow (15%~75%) or red (<15%), charging status indicator: red (charging), green (charging completed) both positioned on the "O" letter on the center of the panel.
● "10th Anniversary Edition" inscription on back, Zero in inscription doubles as a LED power indicator.
● A front and back tempered glass screen protector is included to protect the glass panels from damage whilst the metal ring on the tail can be connected to the included key chain for simple and convenient carry.
This is not only a celebration of Olight's 10 years of innovation but an entirely new type of flashlight for the illumination industry. The limited-edition titanium Olight ION on GearVita is the perfect gift with it’s custom brightness level settings and premium look and feel: https://gearvita.com/olight-ion-rechargeable-led-flashlight-320-lumens.html
Related products:
https://gearvita.com/tank007-wf01-mini-wearable-flashlight-280-lumens.html
https://gearvita.com/acebeam-uc15-keychain-light-1000-lumen.html
