Pm on its way , thank you.
Any body else in UK?
I'm waiting for you.
Fenix P3D (predecessor to PD32), Also Convoy S2
FH1
Iām in the UK
You are already sending me a FH1 ( thankyou ) , if you donāt get the 5 responses you need for the FH3 ,I have a led lenser P7 it would fit & it looks much better than the lenser pouch , I would gladly take one to help you out
Fenix P3D (predecessor to PD32), Also Convoy S2 FH1 Iām in the UK
I think these 2 torches are a little small for the holster. If you don't mind the size, I could ship one for you.
:) ok, if I can't get enough participator, I will inform you
Well I received my FH1 holster today from this giveaway, and Iād like to say thank you to Thilium7 for providing the sample.
The holster itself is very well made and would provide a good level of protection for the light stored inside, made of a heavyweight cordura material and lined with a suede like material.
Securing it is a large snap connector, a belt clip with a popper to secure it and a loop on top. This is a nicely made bit of kit.
Those are the positives.
Sadly there are more negatives than positives, for me at least and the lights I tried it with.
Due to the nature of itās construction, no elastic and very limited length top closure it actually didnāt fit any of my lights well, and anything with a āheadā it wont fit at all. Therefore the number of lights this will fit is quite small - it has no give or adjustment.
The two that did fit in, were rattling around inside and not held securely. The only lights this is going to fit properly are fatter straight ones without a wider head, since there is no elastic to stretch or hold things firmly.
Like I said, for a specific model of light it would be fine, but since I donāt have any I canāt tell you what they would be! Depending on how you look at it itās either a good thing, or a bad thing. Good in the respect it would fit a specific light like a glove, but it has to be an exact fit for that to be the case. Bad in the respect it supports only a narrow selection of lights that will properly fit inside.
I often use my holsters for a range of lights, so this is of no use at all for my circumstances. This is more like a āboxā than a holster. Perhaps having an adjustable flap on top where it joins to the clip or on the bottom half of the clip may have helped, though even then the flap has some sort of stiff board inside so wont bend over the top.
The Xtar TZ28 holster on the other hand fitted every one, with only the X6 Se and X1R having slight movement inside, but it still fitted them better than the Weltool one.
So, would I recommend it? hmmm, not really. There are too many limitations no room adjustment at all.
If I got it supplied with a particular light Iād bought that it fitted properly, then great, itās really well made and would be useful.
Would it protect it better than another holster ? probably not. In fact the elasticated ones hold the light away from the sides by gripping it in the middle of the holster thereby giving it a bit of extra protection if dropped as the sides are wider. If you dropped a light in the Weltool holster the side of you light would be offered little protection as itās in direct contact with the sides of the holster.
Iām sorry if this all sounds a little negative, itās just an honest review based on the lights I own - but if you had an exact fitting light it would be good, though Iād still rather have one with a little adjustment.
I would say put elastic in both sides and also lower them allowing for a āheadā, put adjustment straps on the clip (only short ones) and remove the board from the flap - then it would fit a much wider range of lights.
Oh and Henk, there is no way your C8 will fit in this!
I tested it on 5 different lights - The photos with the open clip wouldnāt even come near to being able to close.
Xtar TZ28
BLF X6 SE
A BLF special , for the life of me I canāt remember the name of itā¦ā¦
Eagle Eye X1R
Astrolux S41
The next photoās show the Xtar holster, you can see how the elastic helps.
Hi, G0OSE. Thank you for this detailed feedback and the advice. I will think about the adjustment problem. These 2 lights, will they fit? A little loose?
Yes, they fit fine, but there is quite a bit of slack so they wobble around - itās not a bit problem though. If I had the choice of them wobbling around or held firmly, I would choose being held firmly - but thatās just my opinion, others may have different ideas of course.
Also where the flap is stiff and has no adjustment it wont pull down firmly to hold them so they also go up and down inside, as well as side to side. The buckle is more of a problem than a help. I would put velcro down the front of the pouch, have a longer flap and remove the stiff board inside, then it could adjust to any length - with the buckle it is a set length, so really restricts it fitting a range of lights.
Like I said this is fine if you intend to use it with a light that is āmade forā the holster, ie supply it with a particular light, but if you intend it for use with a range of lights it is too restrictive all round. More form than function!
I am in UK.
PM me.
Zebralight Sc64c
Mine has arrived, the quality is very good , it fits a few of my torches ,pictures will come soon.
Hi,
FH1 Nitenumen NE01 fits well in this holster, it fits a little deep so you have to push it up from the bottom or pull it up by the strap.
The top flap is non adjustable so velcro may help this instead of the connector, velcro would also make deployment quicker, the flap also is a little stiff. If this was going to be used on a back pack then the supplied connector would be fine. Overall well made but adjustability would make it better. My PK Design Lab PKFL2LE fits very well in this holster. Sofirn SF36 and Thorfire VG10 also fit very well.
Guys, come on - Thilium7 just asked for a minimum of 2 photoās to be uploaded for this giveaway, would be nice if everyone who got one to keep their end of the bargain.
Just saying is allā¦
Mine hasnāt arrived yet but as soon as it does I will be taking some photos for Thilium7!
Hi,
Iāve received the FH2. First impressions are excellent. I tried it with 6P Original, Solarforce L2ās, Lumapower M1 and a couple of Ultrafires. All of them fitted well apart from the Ultrafire C2, which was a bit tight around the head.
I was unsure about the buckle. At first I thought Velcro would be better but after using it for a couple of days, I found I can easily use it one handed. Velcro would be quicker but less secure. The fastening was been well thought out.
Pics will follow.
How do you insert pics? It's asking me for a url - they're on my HDD...
How do you insert pics? Itās asking me for a url - theyāre on my HDDā¦
You need to use a site like Imgur to upload your pics to first.
Make an account, upload your pictures then click on a picture and you will see a load of urlās down one side, copy the second url (Direct Link) and paste that into the forum field.
The FH2 is well suited to the P60 sized torches such as the 6P and clones. I liked the fastex-like fastening. The loop around the āfemailā part and the stiff flap kept everything in line making it easy to use one-handed. At first I prefered velcro but after trying it I liked the security of having a clip to hold the flap down.
I tried it with the following:
Surefire 6P Original
Solarforce L2P
Solarforce L2M
Solarforce L2
Lumapower M1
Ultrafire WF502b
Ultrafire C2
Solarforce L2
Solarforce L2P
Ultrafire C2
Lumapower M1
Hi,
Guys, come on ā Thilium7 just asked for a minimum of 2 photoās to be uploaded for this giveaway, would be nice if everyone who got one to keep their end of the bargain.
Solarforce L2P
Solarforce L2M
Solarforce L2
Lumapower M1
Ultrafire WF502b
Ultrafire C2
Thank you for everything, the photos, the support and all advice will be soon discussed and adopted in the next production. :)
The buckle /snaps are awkward at first but people who use them and get used to them swear by them and learn to get their lights / phones /knives etc out fairly efficiently . To me it seems odd and there are better options out there but some people like them .
Hereās a few photos
D1
D4
Fenix pd35 tac
LED Lenser P7
LED Lenser 105
I like it a lot ,the only thing I would change is the buckle & swap it for Velcro because the buckle makes it hard to put torches in reflector first.
