FWIW, the repository’s bin/
directory has scripts to flash tiny13, tiny25, and tiny85. I recommend using those scripts instead of running avrdude directly, because the scripts are much less likely to brick anything.
I’d suggest using the fsm
branch instead of trunk
, if you want the latest code. It’s newer but not as well-tested. Otherwise though, to build everything on a Linux computer, go into the ToyKeeper/spaghetti-monster/anduril/
directory and run the ./build-all.sh
script.
On a Windows computer, it might be simplest to install an Ubuntu environment and do everything from there. It’s relatively complicated getting Atmel Studio configured.
I mean, people could also install a full Linux-based OS, but that usually doesn’t go so well. For new users, the process is typically something like this:
So for a new user it’s usually best to go with a more limited version in a container or VM, which is something Windows 10 supports now.
I ended up buying the driver because mouser and digikey was close to 10 dollars for shipping. But wish i saw this one sooner from aliexpress.
Real cheap. Might still just to fix the old driver.
Help wanted.
I would like to burn the program into NANJG 105 8x7135 linear regulator driver.
I need only BECON mode 2sec on 2 sec of .
I can only find a programs that have a lots of programs but you have to switch it to mode, but I need only beacon mode.
It could be a code from DR Jones LUXDRV 0.22
Could someone make the change to activate only beacon mode? I can make the HEX file.
Thank you
My replacememt Q8 driver finally came in. Flashed Anduril before swapping out the old bricked one. Thank you to Hoop for the write up and Toykeeper for the firmware. The whole process was simple and easy to follow. When im not using the light i set it to the lowest brightness momemtary just in case my 2yr old son grabs it.
hi im getting
avrdude: warning: cannot set sck period. please check for usbasp firmware updat
avrdude: error: programm enable: target doesn’t answer. 1
avrdude: initialization failed, rc=–1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
anyone have any idea what this means?
it was cheap sioc clip from amazon and by looks of it it isnt making physical connection, the pins look too short.
ignore this: avrdude: warning: cannot set sck period. please check for usbasp firmware update
try wiggling your clip or reseating it…i had success with the amazon parts…
if wiggling doesnt work, reexamine your wiring to the clip…
also…pay attention the orientation of the clip to the chip
there is a small circle/triangle near one of the chip legs…this indicates where the clip goes…in the picture it is the lower left leg…see the small triangle/circle? make sure the clip (if correctly wired) has the RESET clip prong on the lower left leg (in the pic) or on the leg with the circle/triangle if the chip is oriented different than the picture.
scroll down this OP link:
This is a short “quickstart” guide on how to flash drivers that use the ATtiny13a MCU such as Qlite, AK-47, 105a/c/d, etc. Flashing drivers that have an ATtiny25/45/85 is similar but the “fuses” and firmware will be specific to the MCU being used. References and relevant links: http://flashlightwiki.com/AVR_Drivers USBASP V2.0 user guide ATtiny13a datasheet Flashlight Firmware Repository by ToyKeeper Attiny25/45/85 FW Development Thread BLF A6 FET+7135 Light Troubleshooting and Mod thread …
What these wires are, functionally, is detailed on the flashlight wiki and in the USBasp V2.0 users guide.
1) MOSI
2) VCC
3) GND
4) TCK
5) RESET
6) RXD
7) SCK
8) GND
9) MISO
10) GROUND
The pins of the ATMEL ATtiny13A chip itself on the driver are as follows:
- RESET
- INP
- INP
- GROUND
- MOSI
- MISO
- SCK
- VCC
a successful flash (depending on what you are doing) will look like this:
found the directory to put the hex…flashed:
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0×1e930b
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file “anduril.2018-08-22.EMISAR_D4S.hex”
avrdude: input file anduril.2018-08-22.EMISAR_D4S.hex auto detected as Intel Hex
avrdude: writing flash (8026 bytes):
Writing | ################################################## | 100% 5.73s
avrdude: 8026 bytes of flash written
avrdude: verifying flash memory against anduril.2018-08-22.EMISAR_D4S.hex:
avrdude: load data flash data from input file anduril.2018-08-22.EMISAR_D4S.hex:
avrdude: input file anduril.2018-08-22.EMISAR_D4S.hex contains 8026 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 4.37s
avrdude: verifying …
avrdude: 8026 bytes of flash verified
avrdude: safemode: Fuses OK
nah the metal contacts in the end of clip arent even touching anything.
it keeps pinging off.
As another reference point, here is what I see during a successful flash:
if all the wiring is correct, clip/chip oriented correctly and wires pressed in tight (some can wiggle loose,—plugging wires in my D4S was an exercise in tedium as wires would pop out as I was putting others in) I can only suggest carefully clipping it on. It will probably only grab the upper legs near the chip and not the lower legs near the board. if that fails…you could carefully try bending the clip teeth prongs out a bit with a small screwdriver or other small tool…
many others have had success with this black clip…
hope this helps…and good luck!
very satisfying when it works!
It took me many many many tires to get my clip to connect. Have a cheap driver I was going to practice on and it jumped off every time. I would hold my breath, and it would still jump off. Don’t give up. Walk away for a bit if you need too. Oh and make sure you have your programmer plugged in. Yes I did that too.
I usually just press on the clip to hold it onto the chip during flashing. It does not usually stay on by itself.
It may also be worth mentioning that some drivers can’t be flashed without physical modifications. Like on Convoy’s recent drivers, from what I recall, pin 5 is connected to ground. So it needs a trace cut before it can be flashed. And on the Fireflies PL47, when the aux LED board is connected, it cannot be flashed. I have to unsolder the aux LED wire, then flash, then reattach the aux LED wire.
But most drivers can be flashed without physical changes.
its not happening,
i dont think its the mcu connection so much as its the pins on the back of the clip
theyr too close together so female cables dont fit and and im finding it impossible to solder male ones.
i ordered some 1mm heat shrink in hope that i can squeeze the together but failing that im done coz its not worth spending $25 on a soic clip to add a couple modes to a $7 convoy.
bend the wires on the clip:
It’s still in the mail from China, but my guess is the same. On my first clip the posts were too close as well. But that’s no problem, just bend 2 connectors down a little, and the colored ribbon connects just fine. [image] Edit: better picture
Bending the pins on the clip didn't work very well for me because they are very short and the small connectors on the cables were not keeping a good contact so i eventually removed the black plastic part on each wire and soldered each 1-pin-connector to the correct clip's pin.
An other upgrade was to file somawhat the sharp edge of the clip mcu-side so it's easier to seat the clip on the mcu when other components are very close to the mcu (i had that with the resistors from the voltage divider bridge on some convoy boards)
i did the bend connectors trick and they hold a bit firmer and i cut 1mm off the front of the clip and still not connecting.
so goes in bin now, not worth the hassle.
thanks for your help though.
is the led suppose to come on when i attach clip?
its still coming with same error though.
