Got my paracord from the exact same supplier. We do not camp in the wilderness but on family campsites. Often there is quite some ambient light from the facilities there. Maybe there was to much ambient light for the GITD paracord to actually work/be visible?
Are those beads large enough for the paracord to ge through?
The ambient light may have been an issue, but what light source did you use to illuminate the cord? The UV light I use is pictured above in the background. Most common flashlights wouldn’t induce the same intensity of glow, as they are in wrong spectrum. Sorry for mentioning it if you already know… I haven’t read through the whole thread.
Yep, two strands can easily fit… maybe three if you force it in there.
And as for the paracord, it’s all I’ve ever used and never had an issue. You might need to re-stake after a good rain/stretch, but should stay taught after that. (Soak them prior to running your lines, to avoid re-staking)
Just had them laying around in the (scarce) sunlight. Will do some more testing once we are off for longer with the tent.
Won’t be using paracord for guyline though, since we have a ginormous tent with 10 or 12 guylines. I found the following for European users looking for reflective guylines: Polyester/Dyneema®-Kordel, Zeltleine, reflektierend, 2,5mm | buy online | extremtextil
However I do find everywhere that you shouldn’t put knots in Dyneema, I still think this is the strongest and best option regarding reflective guylines.
That’s mostly the case with the ‘naked’ braided Dynema such as Amsteel Blue because Dynema and Spectra fibers are Teflon-like slippery and most knots won’t hold well even at moderate loads. The cord you’re buying is a kernmantle construction with Dynema core and polyester sheath - most knots will be fine, though line may feel a little stiff compared with regular Nylon paracord. Another property of Dynema cords is their super low stretch - some 4% at break (Nylon would normally stretch more than 30% near the breaking load).
Reflective guy line This stuff is great. It’s perfect for your use. It’s an American company, but they do ship internationally. I don’t know what that would cost though, it may make it prohibitively expensive to order in smaller quantities.
I had heard people recommend Atwood rope for years, and I finally got around to ordering some. The price was good, the shipping was fast, and the quality of the micro cord and 550 cord I got seems to be very good. I would definitely recommend buying from them.
Forgot to update, the GITD lineloks were okay. Remarkably, the glow in the dark tops on the naturehike “nail” type tent pegs was at least as good, possibly better. Between glowing peg and “floating” Lineloks, it was easy enough to avoid the lines. With a single glowing point, it is difficult to determine the direction of the lines.
I’ve now fallen down a rabbit hole of photoluminescent materials, seems like you really do get what you pay for, I’ve found there are classifications for glow longevity under test DIN 67510: mcd/m2 measurements are taken at 10 minutes and 60 minutes, values correspond to the “grade” of the material, increasing alphabetical letters are more glowy. I’ve found very few places with Class E, and it’s expensive .
Link to a website with the values for each classification, Class E is missing
I don’t have Eagle but my friend will be converting the source files to KiCAD for me, ideally I’d like to make a version compatible with JLCPCB’s SMT assembly that could be semi-mass produced. No way I’m hand-assembling 20 of these which is the ideal number
Yesterday i’ve stumbled upon rechargeable fishing chemlight replacements on Ali so i’ll be testing those. If the runtime hits at least 8 hours it’s a win for me since i rarely spend more than one night at any given location anyway. My use case is mostly finding my bivvy in the dark and not getting neglectfully murdered by drunk hunters (happens here). Chemlights do the trick so hopefully this works comparably well.
Same but tbh how much energy can one store? Low tens of mAh it seems and massive internal resistance to go along with it. I might order a bunch and short, burn and reverse charge some to assess their destructive power.
