A problem suddenly appeared today. The light will randomly flicker and not reach full brightness in all modes using all 8 of the 7135 chips (modes 17-22). Using the FET channel, there is no problem. Also, modes using 1 7135 chip (first 16 brightness modes) are fine. It is not related to the thermal regulation because I’ve changed the temperature setpoint all around and it makes no difference.
Could one of the 7135 chip connections be bad and cause this behavior?
I had bought another H17F driver to use in another build, so I stuck this extra one in my S2+. I will see what mtnelectronics says about the malfunctioning driver.
Just to expand on this idea some more: with the LG D1 cell at about 3.9V OC, the current was just under regulation at about 2.8A in mode 22. The current was very close to the regulated value of 2.93A, but the regulators did not have to burn off any extra heat, so the driver temperature stayed lower and thermal regulation did not happen in the first 2 minutes. Then when the cell was charged to 4.15V OC, thermal regulation again happened in about 30 seconds in mode 22.
At close to full charge, a typical high performance cell will provide 3A at around 4V. The 7135 chips then must dissipate 0.45V*3A=1.35W, but this is only 0.17W per chip. This is within specs for the 7135; the data sheet suggests that at dissipation powers above 0.7W, additional heat sinking is required to regulate the junction temperature below 120C.
So the question is: because the temperature sensor is on the driver and not closer to the emitter, is the thermal regulation stepping down the current too much too soon? Maybe so, but it should only be a problem when the cell is close to full charge. Within several minutes at 3A most cells’ voltage will drop much closer to the Vf of the emitter and the regulators won’t have to dissipate as much heat. Then the driver temperature should be much closer to the pill temperature.
I can’t really think of a better way to do it other than have a separate temperature sensor much closer, thermally, to the emitter. What about an IR thermometer on the top of the driver aimed at the bottom of the pill?
I did some testing of the low voltage protection and voltage indicator function. The low voltage protection behaves as the manual says, but the cutoff voltage for mine was 2.8V instead of 3.0V as the manual says. The current dropped, at 2.8V, until it reached 1.4mA, then stayed at that value for many seconds until I stopped monitoring.
It has the capability to blink more than 10 and fewer than 3, these are just the voltage levels I measured closely. This pattern is pretty close to each blink corresponding to 0.1V above 2.8V.
Having the sensor on the driver is an obvious compromise, but one I will take for the majority of smaller lights. I have done them on the pill or body thermal shelf before, and it is not fun wiring those things up inside of a small pill.
I just put this driver into a copper sinner I sold for a friend. Outstanding. I loved the lucidrv drivers I was using before but this is a nice step up.
Insane moonlight mode and direct drive. Double tap mode. Just amazing. Now can we get something in 15mm?
Based on the double tap, I deleted turbo from the mode sequence and now I have moon>low>mid (3mA-380mA-1520mA), and double tap to access turbo. Then I set group B to a dummy group and only has low-high (380mA-2150mA) with PID set to 50°C.
I just installed this driver in my triple xpl BLF X6. I’m loving it, its pretty amazing.
I went with low 4.2mA, mid 380mA, high 3040mA, and double tap for even more turbo.
I’m surprised the little fet works so well. I haven’t taken amp readings but the flashlight gets just as bright if not brighter than the MTN-17DDm I just took out and that fet is much larger.
I also lowered the temperature from 60C default to 50C, and turned off memory.
I haven’t decided what to do with the second mode group yet.
Yes, it is very unfortunate that there are so few options for advanced E-Switch drivers.
This needs to change. To spur this, I’ll post a mod detailing how to easily convert any rear clicky light to an E-switch light using no special tools and commonly available hardware store components.
I have not looked at the one I have, still waiting on parts to use it. I did not realize there were e-switch contacts already there… Open mouth… insert foot!
